bizhub c250i
  • Printer77
    • Sep 2019
    • 58
    bizhub c250i
    Hi I have another problem with Bizhub c250i. Machine uses too much developer and creates toner lines on drum. It started on cyan then yellow. I changed drums and refill developers, but now magenta started to do the same. Here are imagesbizhubc250i.zipbizhubc250i.zipbizhubc250i.zip
  • Synthohol
    Certified Konica Expert
    • 5816
    Re: bizhub c250i
    try replacing with new OEM parts.
    sometimes aftermarket components just arent up to task.
    • tsbservice
      Field tech
      • 8006
      Re: bizhub c250i
      Yeah using aftermarket parts and then throwing weird problems here...classy move
      • Woxner
        • Jul 2011
        • 845
        Re: bizhub c250i
        At KM we were using aftermarket toner to fill the void. Turns out this stuff is worse then ever. anytime someone put this in the drum got destroyed. we are not using it anymore once its all gone. I was going through 5 to 8 drums more a week fromthis crap. It also does not fuse well on I series.
