Bizhub C458 Smb registration problem
  • jerry_lam1210
    • 5
    [CQ] Bizhub C458 Smb registration problem
    Hi guys!
    Bizhub C458 Smb registration missing user name and password boxes.
    THX!
  • Synthohol
    Certified Konica Expert
    • 5875
    Re: Bizhub C458 Smb registration problem
    how about on the copier itself, are you able to enter a name and password through the control panel?
    have you tried from a computer? a different browser? does the function version match the firmware version?
    • tsbservice
      Field tech
      • 8035
      In the administrator mode, select [Network] - [SMB Setting] - [Client Setting] and check settings.
      • otphas
        • Aug 2019
        • 121
        What function version is your Firmware ?
        • ionutkok
          • Nov 2012
          • 24
          Try : Service Mode : System 1: Initialization : Clear All Data .
          Change Browser or IP, Clear All Coookies ...
          • emujo2
            • Mar 2017
            • 1579
            This is a horrible recommendation. I'm glad you're not a surgeon. This man has a broken toe.."cut his leg off"..A clear all data should be the last thing you try as it will probably not fix your issue and will add many others. E
            • emujo2
              • Mar 2017
              • 1579
              Try : Service Mode : System 1: Initialization : Clear All Data . <br>
              <br>
              <br><br>This is a horrible recommendation. I'm glad you're not a surgeon. This man has a broken toe.."cut his leg off"..A clear all data should be the last thing you try as it will probably not fix your issue and will add many others. E<br>
              <br>
              • tsbservice
                Field tech
                • 8035
                <br>
                I'm not that hard on clear all data. When someone knows what to do it's not big deal.
                I can do it and setup machine with card reader in probably less than half an hour.
                I'm not recommending this as routine but instead of doing circles around machine trying this and that for hours and hours often start fresh can help.
                • emujo2
                  • Mar 2017
                  • 1579
                  Any chance you have authentication enabled? Specifically external auth and single sign on? I think this would remove the requirements for login name and password as the machine is already on the domain and has rights to certain folders based on this login. E
                  • petertrannguyen
                    • Feb 2024
                    • 3
                    Originally posted by jerry_lam1210
                    Hi guys!
                    THX!
                    I got the same issue were you able to resolve it?
