Creo IC-314
  • emujo2
    • Mar 2017
    • 1580
    [Misc] Creo IC-314
    Widows is giving me a C disk full message (50MB free of 500GB). The CREO is showing system disk at about 40% and image disk about 5%. I have run the creo tools to delete unused files on the system and image drives (after necessary patch), done defrag, and disk cleanup as an admin. I have inspected every temp and log file (as well as hidden) and these are contributing less than 1-2 GB of C drive space. This Creo has probably been running without any user maintenance on it for 8 years. At this time, and job sent with variable data is getting help up and giving a disk full error message. I can still process a plain PDF file. Any ideas as to where this mass of stored data may be coming from. Not quite ready to do a reinstall of the controller software yet. E
  • femaster
    • May 2011
    • 1458
    Re: Creo IC-314
    I'm not going to pretend that I know anything about what you are talking about, other than it sounds like you are working under a Windows environment. If it's possible to run outside software on that setup, an excellent old-school piece of software that I still use to this day (and works on any Windows install from Windows 95 through at least Win 10) should help you find what is taking up all the space. It's called WinDirStat. Essentially it scans whatever drive, drive letter, or directory you tell it to and generates a list and graphical output of every file and it's size in the area you told it to look. The graphical portion creates squares in sizes that represent the size of the file. It makes finding what is taking up the most space very easy to visually see.
    The website will probably describe things better than I have, but it can be found here:
    WinDirStat - Windows Directory Statistics
    • emujo2
      • Mar 2017
      • 1580
      Re: Creo IC-314
      Thanks, this is a cool program
      • femaster
        • May 2011
        • 1458
        Re: Creo IC-314
        No problem. I've used it since back in the Win XP days. A very handy tool to have in your toolbox if you do any sort of PC work, especially on older systems of systems with limited storage space.
        • Synthohol
          Certified Konica Expert
          • 5735
          Re: Creo IC-314
          look for dead spool files in C:\Windows\System32\spool
          sometimes incomplete print jobs will squat on HDD space.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3945
            Re: Creo IC-314
            Quite true.
            Any Windows machine acting as a print server is susceptible to this.
            You'll probably find a bunch of .spl (spool), and .shd (shadow) files.
            • REGSIS
              • May 2016
              • 434
              Re: Creo IC-314
              Take out HDD an put it in a linux based PC. You can even use live CD/DVD or even USB (eg. UBUNTU) and mount that drive. Select "Show hidden files" from Files application menu and enable "Delete permanently" from Preferences submenu. Check properties for size of each directory (Right mouse click on folder). When an enormous size is shown you will know that your unneccesary files are there.
              Delete them to free space.
              • emujo2
                • Mar 2017
                • 1580
                Re: Creo IC-314
                Backed up the Creo, uninstalled/reinstalled ver 3.0, imported the backed up file, defaulted the Look Up Tables (LUT), freed up about 40 G and customer is printing again. I did double check that the auto delete jobs function is on and hopefully we will be good for the next dew years..Very small, 200GB drive in this box. E
                • Synthohol
                  • 5735
                  Re: Creo IC-314
                  make sure their hold queue is not too full, you can set it to store only 10 jobs or up to 99.
                  jobs in the hold queue can be archived to a local PC to save room too.
