C450I DEAD
  • mikeena
    Branch Technical Manager
    • Mar 2007
    • 220
    C450I DEAD
    Ok guys i have a fun one for people today. I have a C450i completely dead. i have replaced the main power switch, baseboard, hv, dcpu, cpub, memory board, excb, erb board , anfd still dead. i have then also reeplaced all the boards again together dead. No clue. i am lost for words. i get no 24v from cn6 on the dcpu however if i go to another machine i can disconnect cn6 and the machine still comes on. there is no fans on, nothing. machine dont even make a noise.
    No lights on baseboard however i dont thknk there is a light on baseboard but i could be wrong
    i have also replaced the control panel
  • tsbservice
    Field tech
    • 8064
    Re: C450I DEAD
    Bad SSD board usually has another symptoms but give it a shot if anything else fails.
    • Synthohol
      Certified Konica Expert
      • 5905
      Re: C450I DEAD
      anytime ive had an i series play dead its always the cpu board.
      • tsbservice
        Field tech
        • 8064
        Re: C450I DEAD
        You get all that parts from donor machine not new?
        • mikeena
          • Mar 2007
          • 220
          Re: C450I DEAD
          So I ordered 2 of every board brand new and then rolled a machine next to it and swapped parts. The good machine always work with ever board. Dead machine no go. Which leads me to. Believe I have a bad power cable somewhere. All icp on the baseboard are good and no blown fuses lol. Now here's the catch it does not seem as if my switch is getting 5v so I'm thinking maybe the wiring for the switch
          • copyman
            Owner / Technician
            • Sep 2005
            • 4785
            Re: C450I DEAD
            Just to be clear was this a new machine or one that was working and then one day dead? I would be very surprised if there was a wiring issue. But who knows with the crap K/M is putting out there!
            • mikeena
              • Mar 2007
              • 220
              Re: C450I DEAD
              Well it was working and was in the shop. It had a jamming ossie. I fixed the problem and asked someone to put it back together. Back panels ect after I replaced a board. When u came back to shop it was dead and they were like I'm not sure what happened. So I asked the obvious question did you unplug the machine before you put it back together. I got a laugh then of course so I'm not sure lol
              • occus
                • 338
                Re: C450I DEAD
                I guess a wire or the CPUB. Try several time to reseat the CPUB an clean the contacts.
