konica I series-Status notification settings-HELP
  • Mitch Barron
    • Mar 2013
    • 180
    How is going guys, how you guys had a nice Eastersunday, Today here looking for your expertise, I had a client that wants notifications send to me when the toner is about to finish, what I know so far is that in Status Notification Settings the machine can send notifications to anyone with a email address but only when the toner is finish. My question is there is any other way where I can make this machine to send notifications when is about to finish so we can send a new Toner.
    I was thinking maybe there is a software switch to set to make this happen or you guys have any other suggestions.
    thanks
  • Synthohol
    Certified Konica Expert
    • 5804
    Re: konica I series-Status notification settings-HELP
    i thought you can select all warnings when setting up notifications and set the toner warning to come on at a higher percentage remaining.
    • kingarthur
      • 1330
      thanks
      If you are a dealer, CSRC seems to work well
      • tsbservice
        Field tech
        • 7979
        thanks
        This is KM world leaders in this industry and No you can't use email notifications in proper way, only when it's too late. Otherwise yes, CSRC and other third party (usually paid) data collecting softwares will do the job.
        • emujo2
          • Mar 2017
          • 1580
          Consult App DCA, FM audit..Anything that can pull SNMP info from the MIB will work. Does not have to be KM software. E
          • tsbservice
            Field tech
            • 7979
            Maybe I have found something. Will test later.
            - Update machine FW.
            - Set Software SW No.210 (bit 4)
            0x10๏ผšEnabled
            - That should then allow to add notifications "toner near empty" and "waste toner bottle almost full" under :
            • [Utility]
              • [Administrator]
                • [Maintenance]
                  • [Status Notification Setting]
            • tsbservice
              Field tech
              • 7979
              0x10๏ผšEnabled
              • [Utility]
                • [Administrator]
                  • [Maintenance]
              Doesn't seem to work.
              Tested on C250i with FWs P8 and Q6.
              I have no desire to go back to downgrade FW GP8-75 to test.
              • dirtyfingers
                • Sep 2013
                • 35
                works for me on our C250i/C450i series without any SW setting changes
                • [Utility]
                  • [Administrator]
                    • [Maintenance]
                Note - Location setting is under Network>HTTP Server setting
                • Bizhubfixer
                  • Aug 2024
                  • 14
                  Does this work as we cant get it to work
                  • Copier Tech Specialist
                    • Jan 2025
                    • 19
                    You can check this Konica Minolta Fleet RMM .
                    it requires windows server OS.
                    • Bizhubfixer
                      • Aug 2024
                      • 14
                      Many thanks , we were hoping that the switch update and firmware would bring this function in the list as it does for the new C3351i machine range
                      • tsbservice
                        Field tech
                        • 7979
                        As we're running same FW and functional version on 0i machines as 1i machines my logic tells me it's some soft switch related. I have and will compare as soon as I can soft switches on 2 machines. Hopefully we will make it work. Stay tuned.
                        • Bizhubfixer
                          • Aug 2024
                          • 14
                          tsbservice. Thank you so much , I will await your findings.
                          • Bizhubfixer
                            • Aug 2024
                            • 14
                            • plus-COPY
                              • Aug 2023
                              • 26
                              Hi Bizhubfixer
                              As I understand it, you need a solution for devices to send alerts about running out of toner directly to your email. At the same time, you would like to have an influence on the setting at what % of toner consumption the device will send a notification (toner c, m, y, k near empty) so that you can deliver it in time. The first solution for individual machines in different locations is to run notifications in Administrator mode, unfortunately you will never have an influence on the settings in this mode. The second, more reliable solution is the SCRC service or an application that supports it, the configuration in this case is included in service mode and is password protected. No other software based on DCA such as xxxxxfleet makes sense due to the maintenance costs, complicated and time-consuming installation process and problems with firewalls in the user network.
