Bizhub c368
  • Costin1804
    • Apr 2023
    • 4
    Bizhub c368
    Hi,
    I am experiencing an issue with my bizhub c368 at my workplace.
    Initially, I attempted to print using the Konica Minolta mobile print app on my Samsung Galaxy S21 but was unsuccessful.
    Subsequently, when trying to scan via email, I received a "server connection error" message, which I have attached an image of.
    I want to mention that I did not modify any settings prior to encountering this issue.
  • Gift
    • Mar 2011
    • 2459
    Re: Bizhub c368
    I think you can see more detailed infomation in the job log including error codes you can check.
    I'd guess something is wrong with the SMTP config or DNS maybe.
    • tsbservice
      Field tech
      • 7990
      Re: Bizhub c368
      Agree.
      Costin, to display error code try following and post code here:
      [Utility][Administrator Settings][Network Settings][Detail Settings][Error Code Display Setting]
      Select whether to display network error code on the Touch Panel.
      [OFF] is specified by default.
      • elmaligno
        Expert technician KM
        • Oct 2009
        • 302
        Re: Bizhub c368
        [QUOTE=Costin1804;2355701]Hi,
        Field technician since 1994
        • Costin1804
          • Apr 2023
          • 4
          Re: Bizhub c368
          Thanks for your support, The error code was 535 and I re-entered the password into the SMTP email field and the problems got solved.
          Now I have another issues with another printer.(bizhub c4050i color)
          The Konica Minolta c4050i is experiencing an issue where it freezes after approximately an hour, preventing printing, scanning, and copying without any error codes displayed. The printer resumes normal functioning after a restart. I attempted to resolve the issue by checking ERP wake-up from a magic packet/ARP, but the problem persists.
          • Synthohol
            Certified Konica Expert
            • 5808
            Re: Bizhub c368
            svc mode, system 1, sleep on/off choice, set to "permit"
            admin mode, maintenance, timer settings, set sleep to OFF.
            set any other energy saver to max time and turn weekly timer off if it isnt already.
            that should help a lot.
            • Gift
              • Mar 2011
              • 2459
              Re: Bizhub c368
              What happen if you disconnect it from LAN?
              • tsbservice
                Field tech
                • 7990
                Re: Bizhub c368
                I would recommend you to start new thread regarding
                C4050i problem. Mixing different devices with different problems in same thread creates confusions and potential problems for people searching this site.
                Until then I hesitate to contribute messing threads.
                Thanks.
