bizhub C3350 Incorrect Imaging Unit
  • techsxge
    • Jan 2022
    • 660
    Hi there,
    we have a C3350 throwing the Erro from the titel since we changed the chip on the imaging unit.
    We do this on newer A4 Printers many times but on this machine which we do not service a lot anymore we get this error. We changed the Chip with other Chips already and they did not work either. According to Machine, its only the Magenta Unit. All others Units do not throw an error. We checked the wire connection for any issues but have not seen any problems so far.
    thanks
  • femaster
    • May 2011
    • 1504
    Re: bizhub C3350 Incorrect Imaging Unit
    If you reinstall the original chip does it complain? If not, wiring is probably fine.
    • tsbservice
      Field tech
      • 8016
      Why not turn off all consumables life messages. Or it's too late?
      • copyman
        Owner / Technician
        • Sep 2005
        • 4701
        We have had issues with that model just not accepting "some" aftermarket chips. You need the correct chip not to just let the machine know it's new image unit and reset count but more importantly that the correct unit is installed. Unfortunately at this point you will have to install a new OEM unit.
        • techsxge
          • Jan 2022
          • 660
          Machine came in with the exact error message. We dont have another machines that is working where we can take a imaging unit out off.
          • techsxge
            • Jan 2022
            • 660
            It is turned of already. However, if the machine thinks it is the WRONG Imaging Unit, it'll still display this which is the case rn.
            • techsxge
              • Jan 2022
              • 660
              The Chips are from a old batch from which, according to our system, have changed about 17 imaging units in the past so i dont quite understand how this should not work anymore.
              • CP-1015
                • Nov 2020
                • 318
                Are two connections inside the Imaging Unit ok?
                • techsxge
                  • Jan 2022
                  • 660
                  from what i can tell when comparing with other units, yes.
