Konica C458 - error D011
  • PedroRec
    • Jul 2020
    • 4
    [Error Code] Konica C458 - error D011
    Greetings!
    I got a C458 with code D011, its a fairly simple error, but in this case is not the HDD, I already swap between machines, formatted both options (of course), put a brand new one, replace the sata and power cable, replace SSD for a factory reset one(maybe a "new" machine would solve the problem), used the TAR reset(even with de 3x strike like in TPM case), but always ended in D011, the machine only works with HDD turned off in System 2. Im afraid that is like the C754e/C654, or you have the specific firmware or is a dead MFPB, also this is a imported machine, already arrived in this condition, so I dont know any previusly information or context about this equipament
    I have tried a couple dozen base firmwares, but none of these solve the problem, I do not have access to Konica website, I have the service manual, but not the "all solutions" to tell me what special firmware I need. Can someone please send me the bulletin so I can at least know what firmware I need?
  • ionutkok
    • Nov 2012
    • 24
    Re: Konica C458 - error D011
    Hy,
    From Service Mode - Format Phisical HDD , Reboot, Format Logical HDD
    If the code persist, replace MFPB
    • allan
      RTFM!!
      • 5462
      It could be that the SATA drivers are bad or its bad memory bad MCU or just a shot solder joint on the MFPB.
      There were SATA special FW releases in the past not sure about this model.
      Whatever
      • ltdiniz
        Supervisor de Campo
        • Mar 2021
        • 98
        What is the current firmware version of your C458 that has error CD011?
        Enviado de meu Redmi Note 9 Pro usando o Tapatalk
        • copyman
          Owner / Technician
          • Sep 2005
          • 4723
          see attached
          here is best practices bulletin refers to, file to big to upload as attachment:
          The simple, quick and secure way to send your files around the world without an account. Share your files, photos, and videos today for free.
          • PedroRec
            • Jul 2020
            • 4
            V1, but tried all base firmwares up to W5
            • copyman
              Owner / Technician
              • Sep 2005
              • 4723
              Did you see my post? It specifically addresses the D011 code
              • PedroRec
                • Jul 2020
                • 4
                I trying to find that firmware here with local techs as well, if I get i let you know, thanks
                • PedroRec
                  • Jul 2020
                  • 4
                  I just open! Thanks! I will try it later soon as I can!
