c364e Animations, Firmware, Licensed options
  • yakatz
    • Mar 2021
    • 24
    Now that everything is working properly, I did an initialization on my c364e to get rid of some data from the previous owner and, of course, I now need the animations.
    While I am upgrading everything, I am wondering if it is worthwhile to see if there are firmware updates (since everything is working fine).
    Currently:
    MFP Card Version A5C10Y0-F000-G20-M1(00)
    MFP Controller BOOT Program A5C10Y0-1E00-G00-04(00)
    MFP Controller Linux Base Linux-2.6.26.8-rt16
    MFP Controller Kernel Program A5C10Y0-1C00-G00-76
    MFP Controller SubSet A5C10Y0-1F00-G00-M5(00)
    MFP Controller A5C10Y0-0100-G20-M1(00)
    Operation Panel Message Data A5C10Y0-8100-G00-M0
    Fax Board Controller1 A22M0Y0-4000-G00-08(00)
    Fax Board Controller2
    Engine Parameter A5C10Y0-0054-G00-01
    Engine BOOT A5C10Y0-0055-G00-00
    Scanner A5C10Y0-0023-G00-33
    Printer A5C10Y0-0050-G00-31
    ADF A3CF0Y0-0024-G00-12
    Finisher A3EP0Y0-0071-G10-05
    RU
    ZU
    Panel CPU A55V0Y0-8900-G60-00
    DSC1
    DSC2
    Loadable Device Driver1
    Loadable Device Driver2
    SD A3ER0Y0-0071-G00-10
    Voice Data
    Movie Data
    Dictionary Data
    OCR Library
    Panel Sound Data A5C10Y0-C200-G00-00
    MFP Controller Thread Image Parameter A5C10Y0-8B00-G00-01
    MFP Controller PIC Image Parameter A5C10Y0-8A00-G00-05
    MFP Controller System A5C10Y0-1000-G20-M1(00)
    MFP Controller Print Controller A5C10Y0-3000-G01-47
    MFP Controller Print Controller Font A5C10Y0-3F00-G01-41
    MFP Controller Print Controller Demo Page A5C10Y0-3E00-G00-81
    MFP Controller MIO A5C10Y0-5000-G00-U5(00)
    MFP Controller PIC A5C10Y0-8200-G00-B5
    Lastly, am I correct in thinking that I would still need to work with a "real" tech to activate any of the i-Option Licenses (I have the memory upgrade)? For example, things I might be able to use: Web Browser (LK-101 - also requires different firmware?), Searchable PDFs/Encryption (LK-110).
  • Synthohol
    Certified Konica Expert
    • 5822
    Re: c364e Animations, Firmware, Licensed options
    if there are no issues g20m1 is just fine.
    also i sent you a link for the movie data, thanks for being a contributor!
    • rrrohan
      • Sep 2011
      • 1977
      pretty sure anyone can make a login for LMS License Management System
