bizhub 283 low toner
  • Printer77
    • Sep 2019
    • 58
    I changed new toner cartridge but there still shows "Low toner". What to do?
  • Synthohol
    Certified Konica Expert
    • 5840
    Re: bizhub 283 low toner
    take out the toner, make a shitload of copies until it ASKS for toner,then install the bottle.
    konicas get weird if you change the toner before "IT" tells you to. ignore the low toner message until it stops printing.
    never replace toner until it specifically asks you.
    you can speed up the process by printing halftone test pages in service mode @255
    • copyman
      Owner / Technician
      • Sep 2005
      • 4712
      Good advice from Synthohol but also that model is known for gear - coupling breaking inside toner btl / hopper assembly. Cheat front door and see if btl turning.
