bizhub 223 server copnnection error Code 57
  • Techman63
    • Mar 2022
    • 10
    Hi, since Microsoft Windows update the scan to e-mail funtion isn't working
    maybe some authentification problem
    do you have any suggests?
  • Synthohol
    Certified Konica Expert
    • 5907
    Re: bizhub 223 server copnnection error Code 57
    scan to SMB then email from your PC.
    use gmail with an application code to bypass higher TLS requirements?
    you can try to teach an old dog new tricks or just get a better trained dog
    • Techman63
      • Mar 2022
      • 10
      Thanks a lot
      scan to smb of course get ready, but my customer want to use e-mail (
      • Synthohol
        • 5907
        then they need to upgrade to a machine that supports the current security protocols.
        you cant be responsible when a machine has outlived its supported protocols.
        even konica SD card writing software wont work past windows XP.
        its just simply obsolete by todays standards, your customers have to understand the concept and keep up. its not your fault when M$ or Google raise the bar on security standards.
        • mascan42
          • Oct 2008
          • 486
          What are they using for an email server? Is it their own or a service like Office365 or Gmail?
          • emujo2
            • Mar 2017
            • 1579
            I have several of these models that can scan to Gmail..The trick is to follow the recommendation to move to 2FA. DO NOT enable HTTPS. The browser certificate is not secure enough. These settings will still work....
            SMTP.GMAIL.COM
            SMTP OVER SSL..Port (SSL) 465
            USERNAME= X@gmail.com
            Password= App password generated in Gmail
            • Techman63
              • Mar 2022
              • 10
              SMTP.GMAIL.COM
              Thank you! I try all of your suggestions
              • Techman63
                • Mar 2022
                • 10
                smtp.1und1.de
                • Hansoon
                  • Sep 2007
                  • 3401
                  smtp.1und1.de
