TONER
  • artivity
    • May 2023
    • 12
    TONER
    Is the Konica C6000 toner same type as the Xerox 3370 TONER???
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5817
    Re: TONER
    i dont see how they could ever be even remotely close.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4676
      Re: TONER
      OEM's will make machines for each other but Xerox usually sticks with their own design except sometimes with small machines. Don't think Xerox and Kon/Min ever "shared" a machine.
      So to answer your question NO these toners are NOT interchangeable
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        Re: TONER
        don't be so sure about that... Nothing that large, only desktop's.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4676
          Re: TONER
          Not sure if I understand your post or you understood mine? Like I posted Xerox only used other OEM's "smaller" models. The bigger designs are their own!
          • emujo2
            • Mar 2017
            • 1579
            Re: TONER
            Absolutely, like oil and gas, all of these toners come from one very large mountain of toner. All the manufactures do is slap a different sticker on it and charge different rates..in fact you can just pour very fine beach sand in the bottle. IT WILL WORK!!! fun fact. E
            • copyman
              Owner / Technician
              • Sep 2005
              • 4676
              Re: TONER
              I disagree. Not all toners have developer mixed in like Konica Minolta toners have.
              Also not sure about other OEM's but some toners use to be charged neg and some pos so that would create a problem with image process if wrong toner used?
              • allan
                RTFM!!
                • 5462
                Re: TONER
                I had a Xerox owner that bought Konica Minolta toner for his machines because its cheaper and seemed to work just fine....
                Think it was TN319 CMY.
                Its risky stuff doing these things but for the dry electrostatic process to work there must be similarities and if the toner dev mix falls with in the same development band it will work. But if not then you will have all kinds of trouble.
                Whatever
                • emujo2
                  • Mar 2017
                  • 1579
                  Re: TONER
                  Yeah, this was just a sarcastic response to the OP..
