SERVICE MODE BIZHUB C554e unable to enter
  • Enzino
    • May 2023
    • 7
    To enter the service mode normally you do on the numeric keyboard "STOP" 00 and then "STOP" 01, but on a customer's machine at the first press of the red button "STOP" the machine makes a double beep and ending the sequence does not take me anywhere
  • cube10025@gmail.com
    • Aug 2022
    • 55
    Re: SERVICE MODE BIZHUB C554e unable to enter
    Are you logged in as admin, won't work if someone is logged in
    • Enzino
      • May 2023
      • 7
      No one else has logged in, how do you enter as an administrator? sorry but normally I deal with kyocera,
      I try to do this operation from touch to enter the service mode
      • copyman
        Owner / Technician
        • Sep 2005
        • 4657
        Are you on the counter page before entering Stop, 0,0, stop, 0,1? Menu, counter then stop 00 stop 01.
        FYI copier will beep as you press the buttons, disregard.
        Admin pass is 1,2,3,4,5,6,7,8 or 1-8 two times
        • Synthohol
          Certified Konica Expert
          • 5809
          side note, if there is a print, scan or fax in the active job queue you will not be able to enter service mode.
          in those cases you can reboot into trouble reset mode and enter service from there thus avoiding a queued job.
          • splblazer91
            • Jul 2014
            • 204
            A lot of these machines are starting to have issues with SSD boards. Bad ssd board wont allow you into service mode and there are very few boards left. These machines are end of life.
            • Enzino
              • May 2023
              • 7
              And is there a way to verify that the inability to access depends on the SSD board?
              • Synthohol
                • 5809
                Procedure (from main power switch ON)1. Open the front door.2. Turn the main power switch on while pressing the power key.After a short beep sound is made once, release the power key and close the front door. Wait to display the self diagnosis (full check) screen.3. After displaying the self diagnosis screen, press the start key.The self diagnosis (full check) is started.The result of the diagnosis is displayed for every item. (OK/NG)4. After finished the diagnosis for all items, turn the main power switch off.5. If there is an item displayed NG, investigate the NG item and take countermeasures
                  • Aug 2022
                  • 55
