Waste toner bottle warning 8 series, i series.
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 291
    [Misc] Waste toner bottle warning 8 series, i series.
    Good morning colleagues. I would like to ask you about the waste toner bottle warning on the 8 series (IT5) and the i series (IT6). In all these machines I have programmed it to be changed by the technician, not by the user, because according to the service manual, it gives a warning before it stops, and in this way it gives us time to go and change it. But the vast majority of customers say that either the machine does not warn them, it blocks directly (it may be that some do not notice the screen, but not many) or it leaves very little time from the moment it warns them until it stops. I would be interested in the machine warning as soon as the toner starts to fall into the transparent sub-deposit, i.e., warning before it blocks as far in advance as possible.
    Does anyone know more about this problem?
    Thanks in advance
    Field technician since 1994
  • tsbservice
    Field tech
    • 7849
    Re: Waste toner bottle warning 8 series, i series.
    We use PrintFleet and it send us email when there is warning for WTB.
    However we don't leave it after that moment for more of a day or two to know how long it will take to machine stop.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4434
      Thanks in advance
      Don't think the machine can determine when toner starts to fall into clear part on back of waste box, only when sensor gets fully blocked. Also if set for tech to replace waste box not sure it gives an advance warning?
      I would leave it set for customer to replace so it will give advance warning and then have customer notify you when message appears. If they don't it will be same as if you have it set for tech to replace without any warning at all.
      Also could set for remote care to email you message "waste box needs to be replaced soon". Usually once this message appears it will allow a few thousand more prints before locking up.
      • Synthohol
        Certified Konica Expert
        • 5673
        why cant the users change the WTB?
        isnt that like calling a plumber to flush a toilet?
        depending on how often its used ive seen the toner cake up over the tube that goes to the detection window and the augers just dont move enough to break the clumps so the box fills up before it detects it.
        why not empty one when its full, clean it out and leave it there for a spare so if it stops during a job they wont have to wait until service shows up.
        • Gift
          • Mar 2011
          • 2439
          I think the warning phase is too short. Even most of our fleet customers have one waste bottle spare since we can't ensure the replacement arrives in time.
          • elmaligno
            • Oct 2009
            • 291
            • elmaligno
              • Oct 2009
              • 291
              we use this solution for some customers, but when you have more than 3500 machines, the cost of leaving cans just because, is excessive, the machine should warn you well in advance, that's the reason for my question
              • Gift
                • Mar 2011
                • 2439
                Yeah but it's the reality since it's just designed badly. We also ran into more serious issues when KMs famous half-filled toner ended up in the field during the time of toner shortage - fleet remaining calculation couldn't cope and we received many "unfriendly" calls. Since then, many customers don't have just a spare wast bottle but also spare toners since they lost their trust in the fleet solution.
                • tsbservice
                  Field tech
                  • 7849
                  When you put half toners into machine fleet solutions will report decrease from 100% to 50% normally then it drops suddenly from 50 to zero in a blink There is KM switch I believe to be set and machine read half toners as half but then it won't report full toners correct, you can choose your own poison thanks to KM
                  • elmaligno
                    • Oct 2009
                    • 291
                    There is a special firmware for half toners: "GG2-N4 Firmware to measure Gas Gauge correctly when using the half toner bottle"
                    • tsbservice
                      Field tech
                      • 7849
                      Whatever it can be special firmware I forgot already as it is useless in reality when we use half and full toners depending on KM mercy.
                      • allan
                        RTFM!!
                        • 5460
                        We empty the WTB on toner delivery we drop 2 of each toner at a time and the WTB never gets filled up. Our customer are not aware of the waste toner boxes...
                        Every toner delivery includes cleaning the DF, emptying the WTB, removing paper dust from the paper path and checking the counters for mostly roller replacement and service interval by resetting the maintenance counter on every visit.
                        Life as a tech is real boring this way not much trouble to talk about.
                        Whatever
                        • tsbservice
                          Field tech
                          • 7849
                          You do that by book then, good practice. We used to do that servicing Toshiba not so much with Konicas
