Konica Minolta c2070 the start button does not work even though the light is blue
  • macuw12
    • May 2023
    • 5
    First of all, I would like to thank everyone who read this post. This is a bug I've been trying to fix for months and months now, I've called a technician but they couldn't help it (I'm in Vietnam). So I hope you guys can help me to solve this problem.
    - I can't continue printing after jam because when I press the start button the machine doesn't receive the command (start button is still blue)
    - I can't photocopy or scan for the same reason
    however when i enable "test pattern output mode" in test mode in utility the start button still working.
    I am very annoyed with this problem, please help me.
    (in copy mod it not working)
  • copier tech
    • 8142
    Re: Konica Minolta c2070 the start button does not work even though the light is blue
    [ATTACH=CONFIG]58569[/ATTACH]
    What is the message in the top left corner of the screen, looks like replace filter?
    Reset this counter in CE mode then you should be able to copy.
    • macuw12
      • May 2023
      • 5
      It "toner filter replace time", it clean but machine still notifies.
      "Reset this counter in CE mode' Can you teach me how to do this please?
      Thanks you alot and so sorry for my bad english!
      • Synthohol
        Certified Konica Expert
        • 5820
        you sound like an end-user or shopkeep, messing around in service mode especially with a production machine can be quite fatal for the machine.
        contributors seem to get the manual they need somehow
        (1) Checking, setting and resetting procedure1. "Service Mode Menu screen"Press [04 Counter /Data].2. "Counter/Data Menu screen"Press [03 Parts Counter].[Service Mode] → [Counter/Data] → [Parts Counter] 3. "Parts Counter Menu screen"Press [01 Special Parts Counter 1] or [02 Special Parts Counter 2].4. "Special Parts Counter menu screen"Press the button that includes the target parts from the menu.5. "Special Parts Counter screen"As necessary, press [Next] or [Previous] to scroll the "Special Parts Counter screen" pages and check the counter.6. To reset the counter, press [▼] or [▲] to select the target item.7. Press [Counter Clear].8. "Reset confirm screen"Press [Yes] to reset the counter.Press [No] to cancel and return to "Special Parts Counter screen"
        • macuw12
          • May 2023
          • 5
          thanks you alot. now the messege of filter is disappear, but still can not copy.
          "end-user or shopkeep" Of course. In Vietnam, Konica sells new machines with the price that I have to work for 2 years to recover capital so we have to buy used machine and need a lot of repair. Poor country you know =)))
          • Synthohol
            • 5820
            does it still say call service?
            just trying to find out why it wont do what its supposed to.
            so we are sure the button is not the problem right?
            if you log on pagescope, does it show any messages or errors anywhere?
            what were the last 5 service codes?
            what are the rest of the consumables at?
            • Todd Glenn
              • May 2021
              • 22
              Do you tap "MACHINE",upper left corner, to see if there is a message , asking Ng you to perform a task, or press continue?
              • macuw12
                • May 2023
                • 5
                It not say call service and i'm sure the button is not problem because when i access service mode menu and access to some of them then exit, the strange thing is i can continue press the button when jamed the job is continue. however things only last for a while before going back to the way they were.
                "what were the last 5 service codes" I'm an amateur so i dont know how to do this.
                • macuw12
                  • May 2023
                  • 5
                  I not tap anything, press continue but it not working.
                  • methogod
                    • Dec 2008
                    • 921
                    Firmware up again, had same issue w 2070.
                    do you have iq installed?
                    • methogod
                      • Dec 2008
                      • 921
                      update firmware, we had same issue, blue start button not working.
                      had to update twice to get it to work right.
