Image Formation - Voltages...
  • stepwik
    • Nov 2011
    • 17
    [Misc] Image Formation - Voltages...
    Hi All,
    I recall reading some really concise information on how the different voltages work. I think it was in training... I kept all the files but I can't find it. Specifically:
    KM C3080 or C3070 (or any machine really...)
    What does it mean if the grid voltages are higher or lower than the default? IE as the drum is worn, the voltages tend to be set lower to create the same density?
    Same question - Bias of Dev, LD Power...
    I recall being told if you look at certain voltages in the Process Adjustment part of list output, you can infer certain things..
    So does anyone have a PDF or URL suggestion that explains all of that in detail?
    Thanks,
    Stephen
    Repair Reduce Reuse Recycle Rejig Retire...
  • tsbservice
    Field tech
    • 8008
    Re: Image Formation - Voltages...
    Originally posted by stepwik
    Hi All,
    Thanks,
    Stephen
    This PDF should be your service manual. Read about Vdc and Vg.
    • stepwik
      • Nov 2011
      • 17
      I found some hand-waiving discussion but nothing that gets into what higher or lower voltages mean...
      "(8) V0 correction control(a) Purpose
      (b) Method
      humidity, and the slide distance of the developer.
      external temperature, and the slide distance of the photo conductor."
      • Synthohol
        Certified Konica Expert
        • 5823
        the grid voltage increases with wear/usage to compensate.
        this is why images look like crap when the counters are reset without changing the consumable itself.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4682
          This compensated increase in grid voltage is why developer will dump if drums are way over life. The increased grid voltage shorts out.
