SMB scanning in Windows 10 Azure Active Directory environment.
  • copierwhisper
    • Mar 2013
    • 78
    I have a customer migrating from Active Directory to AzureAD, SMB is working on the Konica Minolta C458 with Active Directory. Once the end user converts to AzureAD with their new credentials we get a login error despite attempts to configure AzureAD correctly. Suggestions or standard configuration to allow the end users to scan to SMB while operating AzureAD platform?
  • Synthohol
    Certified Konica Expert
    • 5905
    Re: SMB scanning in Windows 10 Azure Active Directory environment.
    • emujo2
      • Mar 2017
      • 1579
      I'm pretty sure scanning directly to Cloud is not supported on the KM MFPs..The marketplace apps give you some additional scan Apps, but Azure is not one of them..Normally is a situation like this there would be a 3rd party scanning solution ie Auto Store, Dispatch, Paper Cut ect. I did see a free marketplace app that may establish a MFP login, and even the previous attachment shows "import Azure settings" which KM MFPs do not have..Hope this helps a little.
        • 16521
        All of my customers are small and midsize so I don't have to deal with the complexities of scanning to folder over the internet. Some of it sounds like a pain in the ass. Let us know if you find a solution. Good luck.
        • Woxner
          • Jul 2011
          • 854
          cloud scanning is comming to I series
          • tsbservice
            Field tech
            • 8064
            Konicas aren't exactly state of the art software wise. I hate to say that but their softwares are junk. Like Marketplace or bizhub workplace hub those are total marketing faults.
            • progoffice
              • Nov 2008
              • 337
              I had to deal with this awhile back. My workaround was to create a local user on the PC and have the scans go to a shared folder on the local user's desktop. The Azure AD user could then simply create a shortcut to that shared folder on their desktop and access SMB scans that way.
              • jotunn
                • 637
                Nah, have you seen Canon? With their service mode looking and acting like it came straight from the MS DOS era, user authentication designed by retarded "Pajeet", application straight from the 90's to create USB memory with firmware update*
                * Yes I know that you can update firmware online usually, but due to chip shortages there were machines where USB update was the only way.
