Accurio c2060 error c2221
  • slytukana
    • Feb 2015
    • 48
    Hi
    I am having a problem with this error c2221 accurio c2060 machine start up immediately error pops up. This is to do with the image transfer belt unit I try cleaning it or even replace the belt motor but still the same error comes on again.
    I have try running the load check on the belt motor but it's not turning also developer motors are turning expect the belt motor not turning M9
    Any advice on what else I should do?
    Appreciate your help..
    Sent from my TECNO KG5k using Tapatalk
    • 23010
    Re: Accurio c2060 error c2221
    C2221 can be caused by toner dusted sensors PS50 & PS51.
    I've seen C2221, when the drum bore fits too tightly onto the drum shaft. The imaging drawer does not close completely. =^..^=
    • ysshin79
      • May 2017
      • 37
      The toner filter was not cleaned on the 3080 model, so toner was scattered inside, and the 1st transfer roller pressure/release sensor inside the transfer belt was contaminated with toner
      On the 6000 model, the 1st transfer roller home position sensor has been replaced and fixed
      In my case, both of the above models were sensor problems.
      • wjurls
        • Feb 2017
        • 505
        This right here!! Look at the lower right corner of the process drawer when it's closed and see if it is sitting flush against the face of the backing plate. If it is sitting off even a little bit. you will get that C2221 code.
        • JRDZ
          • Mar 2020
          • 1
            • 23010
            Determine which drum fits too tightly on it's drum shaft. In my case it was 3 out of 4. Install only one drum, then close the drawer to see if it closes properly. Remove that drum, then try the next etc, etc. You can install new drums, or file out the drum bore at the rear. Lubrication did not help. =^..^=
