CF5001: yellow background
  • 21043
    • 63
    Hello!
    there is a yellow background on my CF5001, yellow toner not "dusting" inside copier, drums and belt are clean, but transfer roller covered by yellow toner after 2-3 prints. i trying to reset calibration, change drum, belt unit - no effect. if i installing new dev. unit from another Cf5001, it prints good, but after 10-20 prints yellow background appears again.
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Is there a difference between sending print jobs or making copies at the machine? I have seen new vista systems trying to print with XP drivers cause similar problems.
    • 21043
      • 63
      hello!
      no difference, printing from Win2000 and WinXP and from own menus of CF5001 (service mode).
      • minimerlin
        • 851
        Originally posted by 21043
        Hello!
        Are you using genuine toner?
        When you tried a different yellow dev unit what happened when this tank was put back into the machine you took it from? Did it work ok then?
        My thoughts are wrong toner maybe!
        Please do not PM me without asking first.
