Konica Minolta C3350 - scan to email
  • Kenny
    • Jun 2009
    • 534
    hi guys,
    got a weird one, a user is trying to scan to email on their C3350. The very first document works fine sends through straight away, if they then try send a scan to email after that they all fail in till the machine is turned off/on.
    they have a C658 with the exact same set up and that works perfectly fine.
    the C3350 has the latest firmware on.
    could this be a HDD fault? or does the machine need a self signed cert?
    any suggestions?
  • Synthohol
    Certified Konica Expert
    • 5898
    Re: Konica Minolta C3350 - scan to email
    honestly id try a different smtp server just to see if its an issue with the email acct its trying to use or a transmission issue with the copier.
    easy test..
    • emujo2
      • Mar 2017
      • 1579
      You need to provide a little more info..What is the error in the job log during a failure? I'm betting it's a disk full, or relay error message. Someone on your IT side needs to get onto the mail server and see what is happening while the C3350 is scanning..A tougher, but better for the actual answer would be to wireshark/mirror the MFP port. This will narrow it down to what, why and when your little packet of data was not able to get to the mail server..
      • rrrohan
        • Sep 2011
        • 1977
        • Kenny
          • Jun 2009
          • 534
          details:
          smtp.office365.com
          start TLS
          Port 587
          added googles DNS and theirs,
          created an SSL Cert
          turned off all TLS apart from TLS1.2 AND SSL 3.0
          the device email address is the same as admin address, they also use the address for authentication.
          encryption strength is AES-256,3DES-168,RCA-128
          updated to latest firmware.
          I am going to site today to try your suggestions
          is there anything else i am missing?
          • B0265
            • Jan 2007
            • 718
            Is the SSL cert SHA-2?
            • Gift
              • Mar 2011
              • 2459
              The C3350 came with a weirdo controller back then
              Enabled IPv6 can cause such issues from my experience.
              • Kenny
                • Jun 2009
                • 534
                I think it might actually be a machine issue?
                tried to also set up to GMAIL and sends one then doesn’t send
                I’ve also formatted the machine, re configured the machines details, updated firmware again but just won’t work
                • Synthohol
                  • 5898
                  i had half a dozen machines at a school do this and it turned out that the time and date were more than 5 minutes off from the email server time.
                  we set the time manually to match the smtp server and it just sort of worked after that.
                  • rrrohan
                    • Sep 2011
                    • 1977
                    did u use app password or account password
                    • ltdiniz
                      Supervisor de Campo
                      • Mar 2021
                      • 98
                      Hello colleague Kenny, I already had a case similar to yours and the e-mail transmission error defect was like this.
                      Printer 1 bizhub C308 had the Relay SMTP enabled for the IP 192.168.100.200 on the client's SMTP server ok, and Printer 2 bizhub C558 did not have the Relay option enabled on the SMTP Server for SMTP transmission to the IP 192.168.100.202 and in this case the server blocks the immediate e-mail transmission.
                      Have you already checked this?
                      I hope I helped with the tip.
                      • Kenny
                        • Jun 2009
                        • 534
                        the time and date are fine with the machine,
                        i haven't looked at the SMTP settings but will look into this, would this be the case for office365 and Gmail? pulling my hair out with this one
                        • Kenny
                          • Jun 2009
                          • 534
                          • femaster
                            • May 2011
                            • 1519
                            That will definitely give you intermittent scanning issues. Hopefully that is all that it was.
                            • rrrohan
                              • Sep 2011
                              • 1977
                              guy using that PC must never bothered reporting the IP conflict warning that would of been popping up on PC
