C659 box priinting -> limitations?
  • Gift
    • Mar 2011
    • 2459
    I might be too dumb to RTFM but I can't find that intel.
    Customer of mine use the box to collect several jobs over night and print them next day.
    Seems stuff is missing and if he prints a new job in his box it's not showing up.
    Jobs contains mostly 1 or 2 pages but the number of jobs are ~300.
    The user manual says there are limitations about how many files you can store in a user box and also a limit regarding the size / memory capacity, see:
    That's pretty vague and I'd like to know the details - anyone knows these limits?
    Service manual give's me this:
    That's obviously partially BS but 10000 pages Box capacity across all functions might be legit,
    still no information about the number of files.
  • Synthohol
    Certified Konica Expert
    • 5905
    Re: C659 box priinting -> limitations?
    look in hdd capacity in service mode, make sure at least 100Gb are shown vacant on the hdd.
    • Gift
      • Mar 2011
      • 2459
      makes sense, seems the customer can check it too once the issue occured:
      • tsbservice
        Field tech
        • 8064
        Afaik you can't store more than 200 jobs(documents) in one user box. This makes user box functionality pretty much useless in our cases plus storing documents in machine storage (HDD, SSD, SD card) is generally bad idea.
        P.S.
        Page scope box operator is rather lagging and obsolete program too
        • allan
          RTFM!!
          • 5462
          Have you tried ID&print instead?
          You can print all the docs to PDF then dropping it into a hot folder when needed.
          Whatever
          • Gift
            • Mar 2011
            • 2459
            ThanK's for the hints and suggestions. 200 jobs is probably not enough for this customer. Is this also the limitation for ID & Print?
            Manual explains:
            When you print a document from the PC in the user authentication system environment, the files transferred with the ID & Print function are stored in the ID & Print User Box. When a user who has sent the print data logs in to this machine and opens the User Box, he can preview, print out, or delete the stored file.
            Sounds like it's a box, too
