Minolta firmware C284-284 compatibility
  • M1963
    • Jun 2017
    • 54
    Greeting,
    I am using firmware A5C10Y0-F000-GDB-M1(00) on C224e and C284e machines.
    can someone answer
    can i use the same firmware for Minolta bh-284e.
    Thanks for your help
  • Woxner
    • Jul 2011
    • 838
    Re: Minolta firmware C284-284 compatibility
    No its not the same. 284e starts with a61f
    • tsbservice
      Field tech
      • 7975
      Nope it won't recognize it.
      • M1963
        • Jun 2017
        • 54
        could someone send the latest version?
        thank you very much
        • tulintron
          • Jul 2014
          • 669
          thank you very much
          PM.
          • M1963
            • Jun 2017
            • 54
            Originally posted by tulintron
            PM.
            Thanks a lot! Donation goes to the forum!
            • M1963
              • Jun 2017
              • 54
              I upgraded the firmware on the G20-M1 (BH284e) but the smb 2.0 scan still doesn't work for me. Only smb 1.0 is working.
              Does anyone have an idea why it's not working ?
              • Synthohol
                Certified Konica Expert
                • 5799
                GDB-M1 firmware with bit sw 219 will lock in smb 2.0.
                hex 04 will lock in smb 2.0 as the default.
                3
                Konica Minolta
                SMB v2/v3 Support
                KONICA MINOLTA Group CONFIDENTIAL
                SMB v2.0 support
                SMB v2.0 was introduced to IT5 series (e.g. C258) beginning of 2016 with
                function version 2.1
                For following IT4 models a special firmware was released in August 2017 to
                support SMB v2.0:
                DLBT1708055EN: bizhub C754e/C654e
                DLBT1708056EN: bizhub 754e/654e
                DLBT1708057EN: bizhub 554e/454e/364e/284e/224e
                DLBT1708058EN: bizhub C364e/C284e/C224e
                DLBT1708059EN: bizhub C554e/C454e
                DLBT1708060EN: bizhub C754/C654/C554/C454/C364/C284/C224/
                bizhub 754/654
                For IT4 devices, DipSW 219 can be used to select available SMB version for client
                function.
                DipSW 219
                bit 2 enabled (set to 1): only SMB2.0 is supported
                bit 4 enabled (set to 1): only SMB1.0 is supported
                both bits are disabled (set to 0), SMB1.0 and SMB2.0 are supported
                both bits are enabled (set to 1), only SMB2.0 is supported
                HEX bit Setting
                0x00 ###0#0## SMB1.0 and SMB2.0
                0x04 ###0#1## only SMB2.0
                0x10 ###1#0## only SMB1.0
                0x14 ###1#1## on
                do you need it? you are a contributor, i can help.
                i think all versions after GDB-M1 incorporates this setting as well.
                you can also set NTLM to 2.0 only
                At the copier, Administrator, network, SMB Client enable NYLM V1/NTLM V2
                • M1963
                  • Jun 2017
                  • 54
                  DipSW 219 does not allow changes, any bit I set to 1 returns it to 0 (all bits are ns 0 ).
                  is there another DipSW responsible for SMB or Network, so maybe it's causing the problem?
                  • Synthohol
                    • 5799
                    how do you mean?
                    you set the hex to 04 and hit fix.
                    • M1963
                      • Jun 2017
                      • 54
                      i tried several times but it goes back to 0
                      I didn't have this problem on other machines.
                      they gave correct settings for BH284e MACHINE 4
                      TYPE 2
                      I don't have SM so I can't look.
                      thank you
                      • M1963
                        • Jun 2017
                        • 54
                        Greeting,
                        does anyone have an idea how to get DipSW 219 to stay on
                        hex 04 after I click Fix,constantly returns to 0.
                        I have upgraded the firmware to A61F0Y0-F000-G20-M1 (BH284e), SMB 2.0 scanning is not working for me.SMB 1.0 is working
                        all SMB settings checked.
                        • Synthohol
                          • 5799
                          did you try the GDB firmware? not G20.
                          • allan
                            RTFM!!
                            • 5462
                            I feel silly for asking this question, but are you doing the DIPSW settings under <service mode> <system 2> <software switch setting> and not changing the engineSW?
                            SW 219 seems to be 0 by default. There is no reason for it not to "FIX" the value.
                            Try changing any other SW and see if that sticks. Remember to undo that again.
                            Whatever
                            • M1963
                              • Jun 2017
                              • 54
                              Originally posted by Synthohol
                              jesi li probao GDB firmware? ne G20.
                              I haven't tried it
                              I don't have GDB firmware for BH284e.
