Question about the possibility of maintenance stop in 4/ 4e / 8 / i machines.
  • Kapral
    • Oct 2012
    • 44
    Hey Folks!
    I have a question about the maintenance counter and the possibility of setting the machine up in a way, so (like in the older models) it will stop printing when reaching certain point, connected to maintenance counter.
    One of my clients is extremely annoying, he's not very fast to do any maintenance, and when something breaks, he always appeals to the warranty and says that given element should be fixed or replaced under warranty.
    So is there a way to set the maintenance counter to make the machine stop? So he will call service when it's needed?
    Best regards!
  • Synthohol
    Certified Konica Expert
    • 5905
    Item Rotation time excess warning threshold value Life threshold value Life stop threshold value
    Waste toner box -*1 64,000 counts *1,2 -
    Fusing unit - 1,231,500 counts 1,261,000 counts *3
    Transfer roller unit - 615,750 counts 630,750 counts *3 (printable)
    Transfer belt unit - 1,231,500 counts 1,261,500 counts *3
    53,067 M 53,067 M 54,400 M *3
    Ozone filter - 8,773 M 9,213 M (printable)
    Toner filter - Color: 175,000 counts Color: 185,000 counts
    - Bk: 300,000 counts Bk: 315,000 count (printable)
    Imaging unit/Y,M,C - 175,000 counts 185,000 counts *3
    5,193 M 5,193 M 5,540 M *3
    Drum unit/K 8,773 M 8,773 M 9,213 M *3
    Developing unit/K - 1,231,500 counts 1,261,500 counts *3
    • Kapral
      • Oct 2012
      • 44
      Re: Question about the possibility of maintenance stop in 4/ 4e / 8 / i machines.
      Originally posted by Synthohol
      in short, yes.
      in long, yes. you can even have the machine email you.
      just enable life stop for whatever consumable you want.
      Thanks, it was somewhat helpful. But there was a possibility in older machines, that just the maintenance counter could stop the machine. Can this be done now, with newer?
      • Synthohol
        • 5905
        do you have any service manuals?
        service mode works pretty much the same on all those models.
        • Kapral
          • Oct 2012
          • 44
          I'm not sure You understand me right. You go into Service Mode, then Counter, then Maintenance. And You set the maintenance count to be, for example, 30k copies. It counts 30k and then it stops. Can it be done?
          Cause on old machines, like Bizhub 215 it was possible.
          • Synthohol
            • 5905
            i know what you mean, however there is life stop for individual consumables which negates the need/use of maint count stop.
            honestly i havent seen maint count stop used since the analogs.
            but i do know what you are referring to.
            another thing you can do is enable account track with public use and set the max pages through that so when they reach xx,xxx pages unless they know the admin password it will stop working until you reset it.
