Developer replenishment
  • barber782
    • Aug 2011
    • 286
    Hi Peeps,
    Just wanted to know if anyone has tried to replenish the developer on the 8 series or i series machines?
    I know on some older models you were able to get hold of bottles of dev, but didn't know if this was the case here.
    This would only be for when the units dump the the developer due a faulty drum, not for when they reach full life limit,
    Also has anyone been successful converting DR313 drums to fit the i series?
  • tsbservice
    Field tech
    • 8053
    Re: Developer replenishment
    Too early but when the moment arise I would try swapping individual parts from cheaper unit to expensive one i.e. developer powder, cylinder, etc.
    • livancicm
      • Sep 2008
      • 96
      if there is no need for calibration I add anny developer from dv116 onwards . never had any problems.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4765
        You can add developer if it becomes low. Aftermarket bags of developer are sold. But you have to address why it lost developer which is usually caused by over life consumable. Most likely the drum from what ever color is low. But any over life consumable can cause any developer to dump.
        • Gift
          • Mar 2011
          • 2459
          Just convert a BK unit to COL
          • barber782
            • Aug 2011
            • 286
            thanks iv managed to convert a 8 series black drum to a i series drum successfully.
            What would it involve changing the black to colours?
            • barber782
              • Aug 2011
              • 286
