C458 firmwre update issues
  • tsbservice
    Field tech
    • 8001
    Re: C458 firmwre update issues
    I would try to format HDD and attempt firmware again. If no go then format SSD and try again.
    • progoffice
      • Nov 2008
      • 334
      Any update on this C458 firmware update issue? I'm having the exact same problem and have tried everything but the SSD format.
      • progoffice
        • Nov 2008
        • 334
        I ran diagnostics and my R/W Check for On Board Memory came back as NG. This would point to the MFP board as the issue and probably why the firmware is failing to update.
        • FuserNoob
          Service Mgr, CISSP
          • Jul 2022
          • 149
          #19
          Good call!
          Thanks for the update
