Looking for Konica tech in Las Vegas for piece meal work.
  • wjurls
    • Feb 2017
    • 492
    Looking for a tech that can help me out with my remote customer in Las Vegas. Machine in question is a Bizhub C258 with print quality issue.
    PM me if you can help.
    Lee
  • Gift
    • Mar 2011
    • 2447
    Re: Looking for Konica tech in Las Vegas for piece meal work.
    Can it wait till the Formula 1 event?^^
    • tsbservice
      Field tech
      • 7926
      Lee
      What's the issue?
      That makes me laugh 😅
      • wjurls
        • Feb 2017
        • 492
        LOL, I was hoping they could wait until I was out for SEMA at the beginning of Nov.
        • wjurls
          • Feb 2017
          • 492
          What's the issue?
          Apparently an unknown print quality issue. Says it won't print cyan even though it has toner.
          Also mentions errors but doesn't specify code. Awaiting a specific on that still.
          • tsbservice
            Field tech
            • 7926
            Looks like you will need good tech cyan dev unit may be depleted. I would check consumables life and counters all you need is remote panel setup and access to their PC.
            • wjurls
              • Feb 2017
              • 492
              Yup, That's why I need a tech that go go take a look. I can drop ship parts. Dev units nowhere near life on this machine.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4544
                How about the drums, are they they at "0" %?
                Sounds like the Cyan dev dumped which is usually caused by over life drum(s).
                Simple enough to see if dev dumped, walk customer through procedure over phone to get into service mode, state confirmation, level history 1.
                I suspect cyan level will be around "0".
                Tech can add some aftermarket dev to get level around 6.5%.
                Another option is ship customer cyan drum for them to install and then add cyan toner in service mode to bring level up.
                • wjurls
                  • Feb 2017
                  • 492
                  Drums all at 50%, Dev units at 87% remaining. Cyan completely blank. Customer says happened all at once.
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4544
                    If that is the case you are correct a tech needs to look at it. Could be the dev unit isn't turning, bad print head or high voltage.
                    • wjurls
                      • Feb 2017
                      • 492
                      Yeah, looks like a road trip is in my future. I'll make the best of it. They have some 1052's and a C14000 I need to get connected anyway.
                      Thanks.
                      • copyman
                        Owner / Technician
                        • Sep 2005
                        • 4544
                        Just remember on your road trip, what happens in Vegas, stays in Vegas!
                        • wjurls
                          • Feb 2017
                          • 492
                          LOL, this hasn't been my experience. It usually follows me around like on The Hangover.
                          • copyman
                            Owner / Technician
                            • Sep 2005
                            • 4544
                            LOL, same here. I can't get away with anything!
