FS-534 and FS-536
  • mearmi
    • Oct 2010
    • 350
    [Misc] FS-534 and FS-536
    Can we use FS-534 for Konica Minolta Bizhub C300i and C360i. Does it work? As getting issues with FS-536.
    Please advise.
    Thanks a lot
  • mearmi
    • Oct 2010
    • 350
    Re: FS-534 and FS-536
    Please advise.
    Thanks a lot
    Kindly advise Thanks
    • barber782
      • Aug 2011
      • 285
      Please advise.
      Thanks a lot
      Short answer is no, but if you post the problems you are having with the finisher then someone can possibly help.
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        Please advise.
        Thanks a lot
        It's not supported - but it does work. I have a C250i with FS-534SD at home, all functions work as expected.
        You must NEVER update the firmware with the unsupported FS-534 finisher plugged in or you will brick the finisher. That is the big problem.
        I think its possible to convert an FS-534 into an FS-536 changing the board and the lift motor asssy, im sure someone here as done it.
        • rrrohan
          • Sep 2011
          • 1977
          good to know. not sure why ud ever bother trying to convert a 534 to 536 it doesnt seem worth the effort for no benefit
          • REGSIS
            • May 2016
            • 435
            Does FS-536(SD) work on bizhub C368 series?
            I have them mounted on C558, but asking just in case.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4687
              The FS-536 is the correct finisher for all "8" series models but is also backward compatible with the FS-534 used with the "4" series
              • REGSIS
                • May 2016
                • 435
                You are almost right, but not completely.
                FS-536 is finisher for all B&W 8 series, but not all color models.
                C658, C558, C458 - FS-536
                C368, C308, C258 - FS-534
                Similar aproach is applied to i-series where C360i, C300i, C250i uses FS-536 and the rest uses FS-539.
                Chech tech spec for details.
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4687
                  I know what the specs show but almost every "8" series I buy off lease has the FS536. This includes the C258/C308/C368 models. Once in awhile there may be a FS534.
                  • REGSIS
                    • May 2016
                    • 435
                    That info is the answer to my question.
                    Thank you!
                    • B0265
                      • Jan 2007
                      • 718
                      C250i/C300i/C360i have support in the FW for both FS-536 and FS-539.
                      FS-536 will work on the C258/C308/C368 as long as you don't upgrade the Finisher FW.
