C224 Fan doesn't not turn off despite the machine going into sleep mode
  • copyman
    Owner / Technician
    • Sep 2005
    • 4716
    #16
    Re: C224 Fan doesn't not turn off despite the machine going into sleep mode
    Originally posted by doinbox
    The 224 is an upgrade over any of the latest charge roller machines
    I agree the 4 series was better then the new machines with charge rollers. But how are you going to get parts to service it if no longer supported by Kon/Min?
    So once again not sure how a machine that is in "end of life" status be an "up"grade? Doesn't make sense and really sounds stupid.
    • doinbox
      • Jan 2013
      • 110
      #17
      • copyman
        Owner / Technician
        • Sep 2005
        • 4716
        #18
        Nothing to do with the "right" suppliers! Of course you can get aftermarket high mortality parts like drums, blades, etc but what about if you need an oddball part like a gear, sensor, etc? What happens then, your customer is down while you are searching for the part. Sounds like a good way to lose customers.
        Not sure where you get C224's to "up"grade your customers but here in the USA you don't see any. They are done coming off lease so only alternative is buying a newer model.
        Like I posted the "4" series are great and wish they were still around but had to move on. I still have a lot of "4" series I service but upgrading to the "8" series as needed.
        Good luck sticking to your guns, hope you don't lose customers over it.
        • Synaux
          • Mar 2012
          • 1224
          #19
          Originally posted by Kazzy
          I do wonder if possibly a failing thermostat is causing this? If it wrongly detects the temperature, it will inform the fan to keep on.
          Well next time you are there, go into SM and take a look at the temp/humidity readings
