I series SMB scanning
  • emujo2
    • Mar 2017
    • 1579
    [Misc] I series SMB scanning
    550i SMB scanning..Device can see root shared folder, but we get no specified folder (SMB errors 4352 and 16712683) when scanning to //Folder/scan_folder. Government account, the POC I'm working with cannot answer simple questions like, do you need SMB1, what type of authentication do you use, are you using DFS. I have asked him to log onto the server that will host the scans with the user name and password assigned to the one touch. we can write and delete files to this folder so I am ruling out a name/password issue. What would "hide" the folder from the device? TIA
  • tsbservice
    Field tech
    • 8006
    Re: I series SMB scanning
    If I understand it correctly check SMB Browsing setting of machine and enable Sub search. It's in Network/SMB setting
    • emujo2
      • Mar 2017
      • 1579
      I looked at this hoping it might be related, but all this does is tell the MFP to either look for sub folders, or not to. Enabling this adds time to the search results. So in our situation sub search is on, and browsing does display the sub folder, but we still cant get anything to scan to the designated folder.
      • tsbservice
        Field tech
        • 8006
        I would try IP of Host server instead of Name or vice-versa.
        • emujo2
          • Mar 2017
          • 1579
          Same error. we only see the root folder, any attempts to drill down show no specified folder.
          • tsbservice
            Field tech
            • 8006
            Check this thread:
            c450i SMB - Cannot scan to ADS shared folder
            • Ziggy
              • Feb 2018
              • 712
              You mention it was a government account, none of my government accounts allow scanning to smb.
              • chris2882
                • Mar 2011
                • 11
                Sounds like a security appliance is blocking access to the share. Ive had a few of these issues, even with the correct permissions it will block access unless its an allowed device. May need to escalate to I.T., which by all means they should be setting up anyway in a goverment funded facility. I know we try to do as much as we can to make the customer content with our work, sometimes its just out of our scope.
