Firmware Update needed?
  • Hornochse
    • Feb 2023
    • 27
    Hello community,
    we have several Konica Minolta, Kyocera and Develop ineo multifunctional devices.
    On 2 of our Develop ineo+ 224e and on 1 of our Konica Minolta bizhub C224 Scan-to-Mail to Office 365 does not work.
    The firmware on these devices is very old.
    Do we need a firmware update to get this work?
    If so, where can we get that?
    Thanks in advance!
    Alexander
  • Synthohol
    Certified Konica Expert
    • 5842
    Re: Firmware Update needed?
    the e series one may just need GDB-M1 and bit 219 set to hex 04 smb 2.0
    the non e series one, well you can roll naked in legos and try tricking it with firmware and bit switches but seriously its been way long enough time for customers to plan for the machines obsolescence especially 10+ years old. its not a toyota pickup truck. it cant last forever.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4712
      There is a way to make a 4 series NON-E to "E" version (see attached)
      Also attached is bulletin that addresses O365 scan to email
      • Hornochse
        • Feb 2023
        • 27
        Thank you very much @copyman.
        These files are very helpful!
        Do you have a link to the firmwares A1610Y0-F000-GB0-A9.exe and A1610Y0-F000-GB2-K5.exe ?
        Thanks in advance!
        • copyman
          Owner / Technician
          • Sep 2005
          • 4712
          Thanks in advance!
          PM me your email
          • Hornochse
            • Feb 2023
            • 27
            Originally posted by copyman
            PM me your email
            PM sent, thank you!
            • Hornochse
              • Feb 2023
              • 27
              Hello folks,
              I just installed the GB0-A9 firmware on our bizhub C224 to get Scan-to-Mail via Office365 to work.
              Thank you for the firmware! Working great now.
              Does anyone have a firmware for our Develop ineo+ 224e to get Office365 Scans working too? Is it the same firmware like for Konica Minolta bizhub C224e? Would be great to get a link to the fw.
              Thank you very much!
              • CP-1015
                • Nov 2020
                • 323
                Hello folks,
                It's the same firmware.
                Greetings from Bavaria!
                • jwai
                  • May 2018
                  • 508
                  Yesterday I installed GDF-M1 with that soft SW setting, scan for SMB 2.0 failed with server connection error.
                  • Synthohol
                    • 5842
                    well the firmware was GDB not GDF, dunno if thats the issue?
                    also NTLM set to 2.0 also.
                    • Hornochse
                      • Feb 2023
                      • 27
                      Hello,
                      I just installed A5C10Y0-0100-GDB-M1(00) on one of our C224e but Scan-to-Mail via Office 365 still does not work...
                      Any tipps?
                      Thank you!
                      • Synthohol
                        • 5842
                        what is the scan error?
                        • Hornochse
                          • Feb 2023
                          • 27
                          Server Connection Error
                          • Synthohol
                            • 5842
                            no, the error code.
                            usually found in the details of the failure in the log on the screen.
                            its normally 3 digits
                            you may have to turn the feature on.
                            also what is the function level? i think it has to be 7
                            • Hornochse
                              • Feb 2023
                              • 27
                              error code is 107.
                              where can I see the function level?
