C258 slide menu
  • copyman
    Owner / Technician
    • Sep 2005
    • 4788
    C258 slide menu
    I always turn off the slide arrow because it covers the toner gauge on screen. For some reason it won't turn off using Bit sw 227 to all "0"'s.
    Have a feeling it has to do with Bizhub Secure?
    Any suggestions appreciated.
    Thanks in advance
    • 15068
    Re: C258 slide menu
    Originally posted by copyman
    I always turn off the slide arrow off because it covers the toner gauge on screen. For some reason it won't turn off using Bit sw 227 to all "0"'s.
    Thanks in advance
    There is a setting in user mode to turn it off.
    • tsbservice
      Field tech
      • 8081
      Re: C258 slide menu
      C258 display sidebar
      I tried that before and it came back. The following procedure will take care of it permanently.
      To turn off side bar:
      Utility, Admin settings, System settings, Custom display settings, slide menu settings, select on or off.
      Some other settings for side bar are here as well.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4788
        Re: C258 slide menu
        Thanks for the replies. Had to update F/W then it worked
