C450i CE password Rest....
  • Rewind!
    Somehow it works....
    • Jan 2019
    • 89
    We are a small indepented Co. and recently received a C450i. Service and Admin passwords have been changed, everything points to use using LMS to reset the password through a reset code. Our limited access to Konica's resource does not give us the "issue reset code" function. We have tried all the password permutations, and have tried the reset tool to no avail. Any guidance or direction would be greatly apprecated.
    Thank you all!
    JC
  • Brad6784
    • Mar 2015
    • 77
    Re: C450i CE password Rest....
    Thank you all!
    JC
    • ernad
      • Sep 2019
      • 1
      Hi.
      Hope this helps you.
      1. Touch counter then press Stop > 00 > Stop > 01
      2. Enter CE password 92729272
      3. Touch keypad then press Stop > 222 > 00 (Security Service Mode)
      4. Touch Administrator Password
      5. Enter the default Admin password 12345678
      6. Confirm Admin password
      • tsbservice
        Field tech
        • 8009
        Originally posted by ernad
        Hi.
        Will it work on i-series bizhub not 4050?
        • Rewind!
          • Jan 2019
          • 89
          Just wanted to add, that we ended up contacting the original servicer of the unit and was given the CE password they set in the machine. Apparently Bizhhub secure even locks out the reset tool from initilazing the CE password. Got into service and was able to set it back to default.
          Thank you all!
          JC
          • Ziggy
            • Feb 2018
            • 725
            YES, I've been told by a tech that has done this you can't tell anything is happening after you enter the numbers and you have to wait a full 5 minutes after entering code.
