C454 black copies
  • Paulo Borges
    • 16
    C454 black copies
    Hi!
    I'm trying to fix a Bizhub C454 who used to randomly put black on entire page both on color and black prints.
    Is not solid Black. We can still see the printed image, but machine adds black on entire page.
    Started to replace black drum. it fixed in the moment but problem returned.
    Replaced for a good working developer unit from other machine - C224 - but no luck, problem persist.
    I suspected HV problem and replaced the HV board and black drum HV electric contacts from the other machine. same problem.
    Didnt replaced black developer electric contact cause it is part of main drive unit and they are diferent betwen C224 and C454.
    when I print gradation color paterns in service mode they are printed with black too.
    All components are OEM.
    May a fault led erasing lamp be causing this problem? Going to replace it when I return to costumer.
    Does anyone have a clue to solve this problem?
    thanks in advance.
  • Albonline
    • Sep 2008
    • 1153
    Re: C454 black copies
    Originally posted by Paulo Borges
    Hi!
    thanks in advance.
    Is there developer being transferred onto the belt? i have seen this when developer bias leaks away. i have also seen the print head do similar things but if its the ph defects are within the normal print area. not edge to edge.
    • techsxge
      • Jan 2022
      • 660
      Is the black colour layered evenly or are there any hotspots to be seen?
      • Paulo Borges
        • 16
        The defect is edge to edge
        • Paulo Borges
          • 16
          Is evenly
