konica minolta c308 - error memory full printing pdf file
  • andrew088h
    • Oct 2023
    • 3
    [Error Code] konica minolta c308 - error memory full printing pdf file
    Goodmorning,
    I have a Konica minolta c308 with 2gb ram, when I print PDF files with dimensions of 10mb the printer goes into error with insufficient memory. While with word, jpg files everything is ok. I tried changing the drivers and printing with foxitreader another program to read PDF but the error persists.
  • Synthohol
    Certified Konica Expert
    • 5891
    Re: konica minolta c308 - error memory full printing pdf file
    purchase UK-211
    set to spool print jobs in HDD
    one of these may help.
    • andrew088h
      • Oct 2023
      • 3
      Originally posted by Synthohol
      acquista
      il set UK-211 per lo spool dei lavori di stampa nell'HDD,
      uno di questi potrebbe essere d'aiuto.
      ok, is possible install module ram compatible? example ram for notebook so-dimm?
      thanks..
      • Synthohol
        • 5891
        its 25 dollars.
        why risk it?
        2GB Memory Upgrade (A87AWY1) Konica Minolta UK-211 i-Option for bizhub C4050i | eBay
        • andrew088h
          • Oct 2023
          • 3
          I will certainly buy the Konica one, but it was to find out if by inserting a RAM from a notebook with the same characteristics the printer can work.
          • Synthohol
            • 5891
            there was one time i tried to upgrade my laptop ram capacity with ram from a copier and it killed my entire OS.
            that was catastrophic with the amount of apps and tools and jig software etc..
            ever since then i dont take chances or risk porking an MFP board trying regular pc3 in a copier.
            YMMV
            • copytech,mike
              CopyTech,MIKE
              • Jun 2014
              • 261
              Originally posted by andrew088h
              Goodmorning,
              Its built in obsolecence. It means its time for a new machine.
              • copytech,mike
                CopyTech,MIKE
                • Jun 2014
                • 261
                YMMV
                The memory full message means its time for a new copier. Your not gonna fix it.
                • tsbservice
                  Field tech
                  • 8051
                  It's not copier nor additional RAM is your problem. Print them of USB thumb drive, does it work?
                  If yes more than likely wrong driver or setting within driver. And don't listen to mike 8 series are solid and still going strong model.
                  • Duplicator
                    • May 2022
                    • 255
                    +1 on the 8 series. Most solid machines we have in the field.
                    Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
                    If I helped you out, please give me a thumbs up! It helps my reputation.
