Konica Minolta Bizhub C554e
  • rajeshkr9177
    • Feb 2013
    • 3
    [Error Code] Konica Minolta Bizhub C554e
    Hi friends
    I have a C554e printer and suddenly it ask me to enter the serial no. It was not allowing me to enter in to service mode normally (Meter count Stop 00 stop 01). I tried trouble reset and from that screen I entered in to service mode. I managed to enter the engine serial no, but forgot to enter scanner serial no. Now the panel hangs after few seconds once restarted. Can I get a software to reset the MFPB completely and enter all new data .
  • copyman
    Owner / Technician
    • Sep 2005
    • 4697
    Re: Konica Minolta Bizhub C554e
    Originally posted by rajeshkr9177
    Hi friends
    The reset F/W wont help.
    Just had same thing today on a C224e. It was a dead battery. All meters were lost. Asking for serial #. I had another "used" MFP board with good battery, moved all the original HDD, SSD, RAM over and worked fine. Only had to input serial #, IP address & scan settings. Only installed the printer serial #, others not necessary.
    • rajeshkr9177
      • Feb 2013
      • 3
      Thanks for your reply. Can I get the MFPB rest software "A145FW.tar" so that I can erase the current MFPB and use it as fresh one by entering the serial no and other settings.
      • copier tech
        • 8144
        We can supply this should you require it.
        Feel free to contact us at either website below.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4697
          Not sure you understand. That MFP board has to have battery replaced. No need to reset with firmware and will not help with dead battery.
          • copier tech
            • 8144
            Yes, if the battery is dead, try updating the firmware for a cheap fix.
