Installed a PK-520, but copier doesn't recognize
  • smp315
    • Oct 2023
    • 15
    [Misc] Installed a PK-520, but copier doesn't recognize
    Hi everyone. I just installed a PK-520 into a FS-536 finisher (attached to a C759). After installation, I followed the manual's steps to configure the punch kit. However, after completing the process, I press the finishing tab on the control screen and the punch option is not there nor through the computer. Any ideas? As always, thanks!
  • Tech09
    • Apr 2020
    • 147
    • smp315
      • Oct 2023
      • 15
      Re: Installed a PK-520, but copier doesn't recognize
      I appreciate the reply!
      Yes, I performed these steps. After touching "decision" it prompts to turn "machine off/on" which I did. I also tried to end then exit service mode before doing the off/on thing as well.
      To no avail either way
      • Synthohol
        Certified Konica Expert
        • 5871
        recheck your wiring front and back.
        • smp315
          • Oct 2023
          • 15
          Thanks for taking the time to reply. I was thinking this last night as well. I installed a punch kit on another C759 and it worked like a charm.
          I just now disconnected and reconnected everything and now the machine panel recognizes the punch and I can get punched output from the doc handler, but my computer still doesn't give me the option to choose 3-hole. In the printing preferences screen (on the "Finish" tab, it says that setting needs to be: "Punch Unit: Other than none".
          In the Printer properties window, I click the "configure" tab and the device option window still has "none" as the setting for the Punch Unit
          Any help is appreciated !
          • smp315
            • Oct 2023
            • 15
            Uninstalled drivers and reinstalled...did the trick! Not sure why the second C759 came online immediately and the first C759 didn't, but I guess it's one of those weird things that will forever remain unexplained.
            Thanks again to all.
            • Synthohol
              • 5871
              glad it all worked in the end!!
