C258 restrict color copying - only b/w
  • Labsy
    • Nov 2022
    • 52
    Hi,
    is there an option on Bizhub C258 to either restrict COPY function to only b/w copies or at least to set b/w copy and hide setting from user? This is a public copy machine, so I want to either admin-lock this setting to only black-n-white, or to remove this setting out of user view to be hardly accessible, so not everyone would be able to change it. Went through all WEB interface, but could not find any related settings.
    Kindly asking for some help. Thank you!
  • albemero
    • Apr 2019
    • 37
    Re: C258 restrict color copying - only b/w
    Yes. You had to activate User Authentication with the Public User. Public user without login. You must set that Public User can copy only BW.
    Gesendet von meinem SM-S901B mit Tapatalk
    • kingarthur
      • 1356
      There is KM Panel Customisation tool that you can use to hide buttons
      • Labsy
        • Nov 2022
        • 52
        Yes, that's what I would love to try. Any download link available?
        • Labsy
          • Nov 2022
          • 52
          Thanx...will try this and stick with it, unless username/password will be default screen, which they will not like and will confuse users.
          • tsbservice
            Field tech
            • 8013
            +1 for this
            • larweedad
              • 92
              I second the KM Panel. I have it on 2 copiers now. Only the Boss can Print in color.
              • dalewb74
                • Feb 2018
                • 1153
                i don't work on konicas. but from past experience on other brands. if you setup user codes. i highly recommend you setup one for yourself, set as admin permissions, and don't give that code to the customer.
                • Labsy
                  • Nov 2022
                  • 52
                  Well, I want to avoid that principle only due to login screen, which will confuse all other 200+ random users. I will probably go with KM Panel Customization tool as soon as I find where to download it from.
                  • Labsy
                    • Nov 2022
                    • 52
                    I just found DIP SW number 71 = HEX 02 should remove Color settings button from panel. Will try this, maybe easiest option.
