BH-4050 (mono) ScanToFolder what protocol is needed
  • Hansoon
    • Sep 2007
    • 3391
    BH-4050 (mono), ScanToFolder what protocol is needed on the client side?
    Is SMB1 the only protocol this older machine can do, or is there higher?
    What Firmware level is needed on the BH-4050 side?
    Hans
  • Synthohol
    Certified Konica Expert
    • 5892
    Re: BH-4050 (mono) ScanToFolder what protocol is needed
    i remember seeing a post here that there is support for smb 2 and 3 with firmware and likely a bit switch.
    if i didnt lose my access id get it for you.
    • and
      • Oct 2011
      • 99
      Hans
      [bizhub 4750/4050] Customized firmware: Support for SMB 2.0 (Without downgrade restriction)
      ID-No. DLCSES_1709377EN
      [Download file name]
      bizhub4750Series_Cont_A6F730GCA00-W51.exe
      bizhub4750Series_Cont_A6F730G0A00-899.exe
      PRI_DLBT1709377EN_0.docx
      2. Changes
      The following restriction relating to SMB 2.0 support has been fixed in this firmware. [Related CSES-ID: ERBUS_1700893711]
      [Restrictions](Related DLLBT1708380EN)
      [Downgrade of Controller firmware]
      When downgrading the Controller Firmware after applied this customized firmware,
      first, please downgrade to any of the versions below, then downgrade to the desired version.
      - A6F730GAA00-W51
      - A6F730G0A00-W99
      • copier tech
        • 8200
        Hans
        As stated above a simple firmware update will enable SMB 2.0.
        Please contact at either weblink below should you need us to supply it for you.
