Konica Minolta BizHub C300i
  • afirshad08
    • Nov 2023
    • 1
    [Misc] Konica Minolta BizHub C300i
    I have the titled model machine.
    After powered on the following error message showing in the display
    "Install waste toner box and close the all doors"
    I have checked the following issues.
    1. Waste toner box is empty
    2. Stabilization not working
    3. Gradation not working
    Please suggest further action.
  • Cantechman
    • Nov 2008
    • 228
    Re: Konica Minolta BizHub C300i
    I would imagine if the waster toner box is installed properly then it must be a bad sensor, Waste toner box set sensor (PS46) or the board or cable.
    • tsbservice
      Field tech
      • 7993
      What's the issue prior that situation?
      Don't worry to give as much information as possible.
      Points 2 and 3 are irrelevant until you solve 1.
      • mojorolla
        The Wolf
        • 2603
        • tsbservice
          Field tech
          • 7993
          [ATTACH=CONFIG]60565[/ATTACH]
          Yeah most of us we know the theory
          Do you happen to know how to cheat this model to work without WTB and with front door open for a troubleshooting purposes?
          • femaster
            • May 2011
            • 1485
            It is nearly impossible by yourself, and still VERY difficult if there are two of you. The only way I have found is to move the arm back and forth to block and unblock the sensor, but of course, only when the box should be rotating. Not very easy to keep a steady pace, at the right speed, and still keep track of whatever you were trying to watch with the box removed, all at the same time.
            • tsbservice
              Field tech
              • 7993
              You Sir are a smart man
              • Oystercopy
                • Oct 2009
                • 623
                I found this happening on a couple of the 8 series machines. I ended up having to extend the "flag" that detects the bottle, by putting some tape on the flag to make it larger. For whatever reason, it didn't like the bottle, although I did put a new one in... weird..
                OC
                • kingarthur
                  • 1337
                  open the right hand door and close it again, i've had a few of these, the door looks shut, but it's not quite shut
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    had this a few times - if its not the sensor inside the front left (either contaminated or faulty) that is activated by the actuator rocking on the cam lobe on the side of the box, it is usually the expansion board (the little one above the base board) that has failed.
                    • allan
                      RTFM!!
                      • 5462
                      Found a couple where the sensor was covered in waste toner. Using contact/electronic cleaner to flush the sensor out works well.
                      Whatever
