RU-515 with FS-534 konica 758 b&w
  • mkdirs
    • Oct 2014
    • 177
    My friends,
    I have problem Konica 758, with RU-515 and FS-534 finisher what causes paper jam in the entrance to the finisher
    I think the reason is the RU-515 stepper motor speed.
    Is there any solution to this problem? like update the finisher firmware!
    I have two machines with the same problem
    I am a Xerox technician Recently I started dealing with Konica Minolta
    In any case, I'm also looking for Konica Minolta 758/754 service manual, firmware and animation guide data.
    I will be happy if you find the solution
    Xerotk.com
    xerox copier technician
  • allan
    RTFM!!
    • 5462
    Re: RU-515 with FS-534 konica 758 b&w
    It takes an FS-536 and a RU-515....
    You will have issues.
    The RU-515/FS-534 combo will work but you need to remove it every time you do firmware for there are small differences with the elevator motor that will cause the finisher to stop working if you use FS-536 firmware on it...
    Whatever
    • mkdirs
      • Oct 2014
      • 177
      thank you for replay
      so you mean that will work ? so why the paper jam at the
      beginning of the finisher.
      Xerotk.com
      • femaster
        • May 2011
        • 1526
        Have you inspected the finisher entrance? The early FS-534 finishers had issues with the black mylar guide in the finisher entrance wearing through at the fold point in the mylar and then would snag the paper causing jams. It's very difficult to see this mylar and the worn area, so it's best to remove the entrance guide plate and inspect closely.
        • mkdirs
          • Oct 2014
          • 177
          Yes, I checked it well and there is no problem
          Currently, I have temporarily solved the problem by raising the last shifter about 2mm per unit Ru-515
          But I think this is not a correct solution
          Xerotk.com
          • kingarthur
            • 1390
            silly question -is the finisher the correct height.... you can raise/lower it on each corner. apart from it not being the right FNS
            • mkdirs
              • Oct 2014
              • 177
              its ok
              any one can share service menual and firmware
              also i need animation guide data for 654 and 758
              thanks
              Xerotk.com
              • allan
                RTFM!!
                • 5462
                Jam code? 7217?
                Whatever
                • mkdirs
                  • Oct 2014
                  • 177
                  Jam code? 7217?
                  NO the code 2936
                  Xerotk.com
                  • allan
                    RTFM!!
                    • 5462
                    NO the code 2936
                    Go to service mode then counters look there for the last logged jam codes. J-2936 is not a valid jam code.
                    Whatever
