KONICA 2060L
  • liondor1969
    • Jun 2016
    • 72
    [Error Code] KONICA 2060L
    Hi wen i start the printer,after 5 min apeare this code C-5403 BLACK SCREAN ..all is down
    Please help my with a solution
  • wjurls
    • Feb 2017
    • 498
    Re: KONICA 2060L
    Cooling fan on the overall control board is either blocked with dust or failed.
    • Synthohol
      Certified Konica Expert
      • 5868
      Re: KONICA 2060L
      Solution1. Rotate FM1 by IO Check (42-18) or manually, and repair or replace it when there is any abnormality. (Wiring diagram: Main body (3/4):21-L)2. Check the connector connection and the wiring between OACB and FM1, and repair it when there is any abnormality.3. Replace FM1.Faulty part isolation DIPSW Control while detached
      ICP fuse on the OACB board?
      ICP2203 FM1 Image processing cooling fan Fan abnormality C-5403
      connector #
      CN2303 Image processing cooling fan (FM1) C-5403
      • zayonc
        • Jan 2022
        • 49
        Re: KONICA 2060L
        Перевод
        The c2070 uses a processor cooler from an unknown Chinese manufacturer. I recommend replacing it with the Culling Master cooler from bizhub Pro 951 A4EUM77000.
        This applies to all models starting from с1060
        • liondor1969
          • Jun 2016
          • 72
          Re: KONICA 2060L
