Bizhub 1100 intermittent C-5401
  • Toxic
    • 698
    I have intermittent error C-5401 on few 1100 machines (cpu fan).
    Cleaned it and greased and it working better but that is not permanent solution.
    A4EUM77000 Radiator /1 complete cooler+fan is quite expensive.
    Does somebody know which only fan could be replaced from some other machine?
  • Synthohol
    Certified Konica Expert
    • 5912
    Re: Bizhub 1100 intermittent C-5401
    how good are your macguyver skills? almost any 24v fan with the same pinout will work, zip ties, jb weld and some creativity would work.
    • wjurls
      • Feb 2017
      • 505
      There is a reason that I own a mini lathe and 2 milling machines. Working on old clunkers requires "outside the box" solutions. I've started making gears to repair the now unavailable
      web drive motors in the 920's through 1200's. They are an oddball size.
      • Toxic
        • 698
        I appreciate your effort to help, but I already know that. And by the way, this fan is 12v not 24v as usual and has 4 wires.
        I was thinking more if someone has a concrete proposal from practice.
        The aggravating circumstance is that this fan is much thinner than standard fans from PC for example , and a thicker one cannot fit because there is no space except to cut sheet metal.
        • tsbservice
          Field tech
          • 8077
          Hi, not much of help but there is old part number for this fan(in case you can extract it from donor machine), check the bulletin below.
          • Toxic
            • 698
            I found already that bulletin my friend but that not helps much, i dont have none of stated machines for donor parts.
            I am thinking maybe there is some else machine model have similar fan but with different PN and there would be helpful somebody's practical knowledge.
