Bizhub Pro 950 Firmware Help !!! Please!
  • oknic
    • Dec 2023
    • 23
    [Dead] Bizhub Pro 950 Firmware Help !!! Please!
    Hello, i am a new user from algeria
    I have a bizhub pro 950 machine
    and i need the firmware or where to download it for this machine
    the machine is dead (red light near the secreen when i flick the main switch with no action when i flick the secondary power button)and in the maintenance guide i read that OACB board firmware can cause the secondary power to be stopped because of firmware absent or damaged
    please help me
  • Afanasy
    • Aug 2023
    • 35
    Re: Bizhub Pro 950 Firmware Help !!! Please!
    Hi, you can download fw and PRI files here
    • oknic
      • Dec 2023
      • 23
      thank you very much for the firmware
      but a problem now is that i cant find ISW Trns and driver of bizhub 950 for ISW Trns
      does it happen that you have them ? or know where to get them
      • elmaligno
        Expert technician KM
        • Oct 2009
        • 302
        https://we.tl/t-wEmJNHyRS0
        Field technician since 1994
        • oknic
          • Dec 2023
          • 23
          Originally posted by elmaligno
          thank you very much for the file
          i just need your help and expertise on this problem of mine
          Do you think its only a firmware problem ? because when i turn on themain power then i flick the switch the sub power switch nothing happens just a red light on the screen
          could it be a power issue or you still think its firmware related
          • Afanasy
            • Aug 2023
            • 35
            What the power save LED status?
            • oknic
              • Dec 2023
              • 23
              constant red
              • Afanasy
                • Aug 2023
                • 35
                I'm not sure that's firmware.
                • mascan42
                  • Oct 2008
                  • 486
                  Yeah . . . you might be out of luck here. If it's the board, that's pretty much the most expensive part in the entire machine, if it's even still available.
                  • oknic
                    • Dec 2023
                    • 23
                    so you think its the OACB ??? not even the DCPS/2 ??
                    • oknic
                      • Dec 2023
                      • 23
                      so its the OACB board then !!! ??
                      • Synthohol
                        Certified Konica Expert
                        • 5906
                        honestly i didnt read through all the details here but i wanted to say i think the bin file for the oacb gets renamed recovery.bin and it may get you a screen back.
                        ill see if i can find the bulletin but i lost KM access last year so maybe somone else here has it.
                        i know i posted the instructions on this site at least once.
                        good luck!
                        • oknic
                          • Dec 2023
                          • 23
                          good luck!
                          so the red light is only a firmware isssue !!
                          that would be of a great help if you can find the file and the thread
                          • Synthohol
                            • 5906
                            im not saying that, im merely pointing out that there is a recovery procedure that might help.
                            • Afanasy
                              • Aug 2023
                              • 35
                              Do you have blinking of power save LED in orange? This status of indication that indicates the need for firmware. If you have only red LED, next step is OACB challenge
