C554 does not pull the sheets tray 1 and 2
  • JC Andres
    • Dec 2023
    • 40
    Good afternoon, I have a Konica C554e that does not pull the blades, they stick out a little, if you lift them but do not finish pulling them completely, I have already changed pfu 3 times, two pfu Drive motors, what do you recommend?IMG_20231228_154829371.jpgIMG_20231228_154809823.jpgIMG_20231228_154821463_HDR.jpg
    Enviado desde mi moto g200 5G mediante Tapatalk
  • Synthohol
    Certified Konica Expert
    • 5922
    Re: C554 does not pull the sheets tray 1 and 2
    1st pic, third white gear from the top looks (from sms quality pic) like there is toner and or developer on what i think is a one way needle bearing on it that may be slipping?
    i really cant tell from the pic, im sorry
    • JC Andres
      • Dec 2023
      • 40
      But that gear has two gears behind it in the Drive, does that toner have anything to do with it? Because the gear at the back that goes to the motor moves that gear
      • JC Andres
        • Dec 2023
        • 40
        Something happens to me with the pfu, when I put the sheet in thick 1 it pulls it well, and in plane paper it doesn't
        • JC Andres
          • Dec 2023
          • 40
          change these gears and motors tooIMG_20231229_102235982.jpgIMG_20231229_102232298.jpgIMG_20231229_102228462.jpg
          • JC Andres
            • Dec 2023
            • 40
            Doesn't it have something to do or a configuration about the registration sensors?
            • JC Andres
              • Dec 2023
              • 40
              also have these errors in service modeIMG_20231229_102430755.jpgIMG_20231229_102424172.jpg
                • 15069
                Originally posted by JC Andres
                also have these errors in service mode[ATTACH]60984[/ATTACH][ATTACH]60985[/ATTACH]
                What are the jam codes?
                Are there any error codes associated with the jams? Like maybe C255X density code?
                • JC Andres
                  • Dec 2023
                  • 40
                  It's 11-01
                    • 15069
                    It's 11-01
                    Does the lead edge of the paper get out of the tray at all?
                    • JC Andres
                      • Dec 2023
                      • 40
                      yes, it leaves the page a little
                      • Toxic
                        • 698
                        Did you replace rubber rollers and one way clutches?
                        That should be first step.
                        Never had any problem with gears and motors on this machines.
                        • copier tech
                          • 8236
                          Good afternoon, I have a Konica C554e that does not pull the blades, they stick out a little, if you lift them but do not finish pulling them completely, I have already changed pfu 3 times, two pfu Drive motors, what do you recommend?[ATTACH]60971[/ATTACH][ATTACH]60972[/ATTACH][ATTACH]60973[/ATTACH]
                          When you say 'blades' what are you referring to ?
                          Did you replace a PFU with a new or used one ?
                          • JC Andres
                            • Dec 2023
                            • 40
                            I mean sheets of paper, I changed clutches for a PFU that worked in another printer, I also changed 3 PFU that I doubt would work at all but it was to test.
                            The sheet passes good when set to thickness 1.
                            • copier tech
                              • 8236
                              Does it feed paper if the tray is set to SEF or does it feed A3 (large) paper ?
