Bizhub 363 paper jam
Re: Bizhub 363 paper jam
I have Bizhub 363 with 2 trays.
tray 1 - problem
I replace all pickup rollers and the solenoid in the beginning of the pickup module.
All the same, the paper can't out from the tray. I attach the pics.
Any ideas how to fix this problem?
[ATTACH=CONFIG]61059[/ATTACH][ATTACH=CONFIG]61060[/ATTACH][ATTACH=CONFIG]61061[/ATTACH]
Take them off & clean with a little oil then refit but in a different position this should do the trick.Let us eat, drink, and be merry, because tomorrow we may die!
Replace the little black one way's and remove/scuff the shiny trace where they run on the shafts with ScotchBrite.
Just did one for a customer on a BH-363 last afternoon with exactly the same symptoms.
Hans“Sent from my Intel 80286 using MS-DOS 2.0”
The items I have marked in your picture.
Plus you have used the wrong rollers for feed & separation, however it may still work once you clean the one way clutches.Let us eat, drink, and be merry, because tomorrow we may die!
Is this a pick-up roller, which is the correct, and I must change the other 2 rollers?Comment
No. The one you marked with an arrow is the lower separation roller and must NOT be of the ribbed type
Have a look:
HansLast edited by Hansoon; 01-10-2024, 06:47 PM.“Sent from my Intel 80286 using MS-DOS 2.0”
It looks to me like the one with the arrow is the sep roller.
The pick-up roller is the one that drops down to "pick-up" the paper. So in the picture it is the one on the bottom.Comment
Yes you are right, the pic is very small. The sep roller also has the white torque limiter. The pick up & feed don'tLet us eat, drink, and be merry, because tomorrow we may die!
Just to be clear there is only one separation roller (red or orange type), The roller that contacts the separation roller is called the "feed roller" and is same red or orange type.
The first roller that drops down to contact paper can be the black ribbed (new style) or you can use same red/orange roller as the other feed & separation rollers.Comment
Everything is better than just Roller or one of the other KonicaMinolta favorite expressions for anything they don't have a good name for, like, “Holder or Guide”.......
