Konica C3850FS - Pages Printing Lighter, then Blank
  • ctn-user
    • Jan 2024
    • 4
    Hello,
    Wondering if anyone can help with this issue:
    Konica C3850FS
    Users were complaining that it is printing blank pages, so I had them turn the machine off until I could take a look. After getting there and testing, pages were printing just fine.. 2 weeks go by and the users don't report anything, but then a few days ago they reported it's been occurring every now and then and they've just been turning the printer off for an hour or two before using again.
    Transfer belt and transfer roller were at 5% so changed those out, but still same issue.. Seems to last about 24 hours before pages start getting light
    Any ideas on what is going to need to be replaced? (sorry in advance if this is obvious)
    Thanks!
  • ctn-user
    • Jan 2024
    • 4
    Re: Konica C3850FS - Pages Printing Lighter, then Blank
    Bump
    • Radiscar
      • Jun 2019
      • 74
      not sure but your toner isn't getting to where it's suppose to. Might be the dev unit.
      Is the toner amount going down?
      jam the copier and see if toner reaches the drum.
      I had an issue where the toner wasn't reaching the hopper -motor wasn't turning the toner and thought it was the dev unit since it was starved
      Motor, dev, and drum along with some boards were swapped and still wasn't working. -motor worked when tested.
      Konica ran out of things for us to replace/check -but we're pretty sure it was the power supply...which was unavailable and made by panasonic
      • copier tech
        • 8138
        Originally posted by ctn-user
        Hello,
        Konica C3850FS
        Thanks!
        Does it happen on ALL colours or just mono ?
        We have see the HVT cause this issue, if you take the board off & clean all the spring contacts, they can get corroded overtime. WD40 works best.
        • ctn-user
          • Jan 2024
          • 4
          Toner amount is going down like normal
          It's happening with all colors, but not sure if I'd feel comfortable with attempting your suggested fix myself
          Know anyone experienced with Konica machines in the southern California area that would be willing to check this out? (paid of course)
          • allan
            RTFM!!
            • 5462
            Is it printing pages that have content blanked out or outputting additional black pages after a job completes. I have a C3850 doing the latter...
            Randomly outputs additional pages after a job completes. Could not resolve this issue yet.
            Whatever
            • ctn-user
              • Jan 2024
              • 4
              Just printing the actual pages that should have content as blank
              This morning the printer had been without use since yesterday and was printing blanks, so seems like it's getting more frequent now..
              • allan
                RTFM!!
                • 5462
                Ok if you unplug the laser data cable it will print blank. Have a go at reseating the laser ribbon cables.
                No weird stretchy prints in there or half blank pages? Any kind of artifacts on the blank pages?
                Whatever
                • AlaskaCopyTech
                  • Jan 2024
                  • 78
                  From what others are saying my bet is on the developer unit, when they restart the machine the developer unit is working but it can only go so long until it is depleted (assuming it's bad) which makes less toner transfer to the image.
