Bizhub press 1250 display screen is reversed
  • otphas
    • Aug 2019
    • 127
    Hi guys ,
    we have a strange issue, when we start the machine the screen is reversed 180 degree , head is down, what is the reason about that issue? Also i noticed that touch screen is not ok, like not good calibration. You must touch the screen 4-5 mm down to touch what you need.
    • 23010
    Re: Bizhub press 1250 display screen is reversed
    I've seen failed displays like this. Also mirror image or upside-down.
    On one occasion a special-ed kid got the idea he was going to tear off the display. He was not successful. He did do significant damage (no ... not covered by the service agreement), and I had wished that I had ordered the whole articulating arm, because I was not as successful at straightening it as I would have liked, and it's not cheap. =^..^=
    • allan
      RTFM!!
      • 5462
      Originally posted by otphas
      Hi guys ,
      Have you opened and reseated what can be reseated on the display?
      Lucky enough not to have had that before.
      Whatever
      • otphas
        • Aug 2019
        • 127
        Hi ,
        yes , we reconnect lamp cable , video cable and touch screen lens cable.
        • wjurls
          • Feb 2017
          • 501
          There are 2 different displays for the 951, 1052, 1250 machines. If the wrong type is installed, you will get the inverted screen.
          • allan
            RTFM!!
            • 5462
            Makes sense. The screen attributes probably differs between models.
            Whatever
            • otphas
              • Aug 2019
              • 127
              It is correct display attached, seems touch screen make a problem , we disconnect it for now and using PC mouse till we find a spare touch screen
              • otphas
                • Aug 2019
                • 127
                What is the difference between 2 types ? How can we recognize it ?
                • wjurls
                  • Feb 2017
                  • 501
                  Screen from one 951, installed on another 951. Plugged right in too as the connectors are the same.
                  They made a change to these somewhere along the line.
                  • wjurls
                    • Feb 2017
                    • 501
                    There are different colored wires visible on the back of the panel on original vs replacement.
                    The serial number on the back will also have a different first 5 digits.
