Have a C458 putting solid vertical bands on the prints, see attached. So far it does it with K and C and just started with M. It starts off feint then gets more solid in a few copies, it doesnt repeat on the same impression but next time it does it it will have moved a few mm. Its intermittent but can guarantee the issue will show in a run of 20 prints.
Have tried updating firmware to latest, HV board, Drums, Devs, Transfer Belt, Transfer Roller, PH Unit but issue still remains. The drum/belt cavity is pristine and the IDC sensors are clean. Theres no P codes in service mode.
Any ideas would be gratefully received.
