Memory upgrades bh c220
  • Andreegington
    • Jan 2024
    • 24
    Hi guys quick question upgrading memory from 2gb to 4gb
    Do you need special type of dimm can you simply add another 2gb into the 2nd slot
    do i need a specific upgrade dimm I have another 2gb dimm from a broken c220 but this just causes my copier to hang on boot any advice would be great thankyou
    Tried to find an answer nobody seems to know
  • Synthohol
    Certified Konica Expert
    • 5799
    Re: Memory upgrades bh c220
    it would not be an upgrade, the UK-203 is the correct ram upgrade however typically its used only for enabling certain i-options
    the item# is A0YDWY1 its about 100 dollars. (if they even make it anymore as that model is 12 years old)
    • Andreegington
      • Jan 2024
      • 24
      Ok so I simply cant take the ram out of the other c220 and use it as an upgrade am I right ?
      • Synthohol
        • 5799
        yeah ive never been able to use another stick from a spare machine.
        most of the copier ram is made by Buffalo or canram.
        the UK kit is likely the only way to go unless you can get ram specs off a UK kit and try to match.
        what are you trying to accomplish with a ram upgrade if i may ask?
        • Andreegington
          • Jan 2024
          • 24
          Ok so there are some usful abilitys using i-option but my company actually uses papercut for print managment and i need 4gb of ram to use web browser yes I know its a paid for system with i-option to get this but there are also other usful addons that would benifit the compant but main reason is the lk 101 license
          • femaster
            • May 2011
            • 1482
            I think what I would do is verify that the second memory stick you have is good. Put that into the first slot, leave second slot empty and see if machine boots with the stick you pulled from the other machine. At least this way you will know if that spare stick is any good.
            EDIT: I just looked up the memory upgrade for the C220. From what I am seeing, it is a UK-203, which the book for the C220 lists it as being a 1GB memory upgrade, not a 2GB. That is probably the issue you are having. I bet the machine can't address more than 3GB of RAM.
            • Andreegington
              • Jan 2024
              • 24
              Yeah already did that perfect no problems as soon as i add it to my machine to make it 4gb its boots and freezes lookin like i have to but the upgrade ram
              • femaster
                • May 2011
                • 1482
                I had edited my post above and added on to it, but it was probably after you had started to reply. It would seem that the C220 is only capable of addressing 3GB of RAM, as the UK-203 for it is only 1GB stick according to the Configuration Sheet for that model. If Papercut requires 4GB, it's possible that you won't be able to use it with a machine that old.
                • Andreegington
                  • Jan 2024
                  • 24
                  That seems like a reasonable reason why it crashes
                  • Synthohol
                    • 5799
                    that model was discontinued a while ago and either serve as a simple copier or boat anchor
                    at the minimum the 4e series and newer will work much better with papercut.
                    good luck!
                    • Andreegington
                      • Jan 2024
                      • 24
                      Well when somebody gives you a machine I guss you learn by findi g out the hard way free not always good
                      • Synthohol
                        • 5799
                        it was a halfway decent machine at the time, the tech back then was like a 1998 nextel and today is the iphone 20.
                        there was no way to keep up to todays features and security with that old hardware.
