Konica-Minolta i-Series and Microsoft O-Auth 2.0
  • i-have-fax-problems
    • Mar 2020
    • 109
    Dear colleagues,
    one customer asked if KM i-series have the OAuth Function (for scan to email)
    Now, as you may know there is the special firmware GP4-and so on
    which should support OAuth 2.0.
    Has anyone expierence with it? Does it work?
    Thank you?
  • tsbservice
    Field tech
    • 8104
    Re: Konica-Minolta i-Series and Microsoft O-Auth 2.0
    I didn't tried but as there is special firmware for this reason why you don't give it a go.
    • Rewind!
      Somehow it works....
      • Jan 2019
      • 102
      Hello All!
      Went ahead and installed the FW for the oauth enablement in the unit and it does not show up in the menu. If I search for OAuth from the menu it appears, but when selected displays a "Item cannot be displayed in current settings" message. I've read the fw documentation and clearly stated that no soft switches are to be turnd on to enable the item in the menu. It does state that the item can only be selected from the units physical interface. Still testing and was wondering if you guys had ran into this same problem as well.
      Thank you!
      JC
      • kingarthur
        • 1405
        Originally posted by Rewind!
        Hello All!
        Thank you!
        JC
        I've installed it on 2 devices - when you go into the Network - Email settings - Email TX (SMTP) settings - you have the option to turn it on. I don't believe that you can do it remotely (PSWC) as you have to be at the device to enter in your authentication settings, as a new screen pops up
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          have played with this special oauth firmware on my c3350i and can confirm that it works as expected. Saving the login token via the web browser. A shame it is not going to be made standard because it would make setting up email scanning a breeze for end users. Slightly concerning is the unknown changes in future that may render the function inoperable though when security standards change.
          • rrrohan
            • Sep 2011
            • 1977
            what makes it easier than typing credentials?
            • Copier Tech Specialist
              • Jan 2025
              • 19
              Dear All'
              Click on the below link to follow step by step on how to configure OAuth 2.0 please like and subscribe
              • leifstoroy
                • Apr 2025
                • 2
                Here is link to a more detailed video:
                • Dianon
                  • Apr 2025
                  • 16
                  Had to install GP4 first, to show up, after that i could reupdate to RF and the option is still there.
                  configured it like in the video above, with one exception. Had first to use an domain Admin (MS365) for the 'App registration', after that i could use the normal user credentials.
                  Works even with a shared mailbox (don't count as paid licence by MS)
                  If the customers exchange adds automaticly a mail footer, it could be, that you recive a mail with a mail attached.
                  Just exclude the account that you use for the mfp from the group that exchange wil add the footer automaticly
                  • NN-GG
                    Tech-IT
                    • Mar 2024
                    • 12
                    With the new OAuth 2.0 option for scan to email, wondering why this can't show up, not sure what they mean by that? At 05/13/2025, the KM said the firmware needs to be at GC2-RF for 0i/1i models. I guess I have to get to the same version and see what happens.
                    At the customer C361i and many other models with the remote panel & webui display the following:
                    "Item cannot be displayed in current settings."
                    • NN-GG
                      Tech-IT
                      • Mar 2024
                      • 12
                      Hello All!
                      Thank you!
                      JC
                      Hi Rewind!
                      I have a similar issue right now. Did you ever find a solution for it?
                      • kingarthur
                        • 1405
                        As far as I'm aware, you can't log in remotely and set it up - you have to be standing in front of the machine
                        • larweedad
                          • 93
                          I second that. The one we did we had to be at the copier to run the auth. 2.0
                          • NN-GG
                            Tech-IT
                            • Mar 2024
                            • 12
                            Originally posted by NN-GG
                            Hi Rewind!
                            Not even the remote panel at port 50443?
                            • copier tech
                              • 8268
                              This little video may help.
                              Please contact us should you need this important update.
                              www.printerfirmware.co.uk
